FME Transformers: 2024.1
BoundingBoxReplacer
Determining the extents of individual features
The BoundingBoxReplacer receives features with any geometry type and individually replaces their geometry with one of:
2D Bounding Box - the minimum enclosing rectangle, with sides parallel to the x and y axes.
2D Oriented Bounding Box - rotated to fit the feature as tightly as possible while remaining a rectangle.
3D Bounding Cube - the minimum enclosing cube for 3D features, including point clouds. The cube is axis-aligned.
Requesting 2D bounding boxes for 3D features produces footprints. Requesting a 3D bounding cube for a 2D feature produces a 2D box.
If an output bounding box or cube has zero area (if the input feature is a single point or vertical line, for example), it will become a point or line as appropriate.
Feature attributes are retained.
In this example, we will generate two types of 2D bounding boxes for a set of transit line features.
Note that there are three features, with an attribute containing their name.
The features are routed into a BoundingBoxReplacer.
2D Bounding Boxes
In the parameters dialog, Replace With is set to 2D Bounding Box.
Note that attributes can be created for the bounding box side lengths, but they are not added by default.
The output features have had their geometry replaced by bounding boxes, and the attributes remain intact.
2D Oriented Bounding Boxes
When Replace With is set to 2D Oriented Bounding Box, an additional attribute is enabled to extract the oriented box’s angle.
We supply attribute names for all three.
The output features have their geometry replaced by oriented rectangular bounding boxes.
Their original attributes are intact, with new attributes added containing side lengths and rotation angles.
Creating Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Transformer |
Function |
Creates one or more new features with box geometry of a specific size and position (when Geometry Object is Box). |
Replaces an existing feature’s geometry with a box of a specific size and position. |
Creates one rectangle that encompasses all features received. |
Individually replaces the geometry of each feature with a rectangle that covers its extents. |
Individually replaces the geometry of each raster feature with a rectangle that covers its extents (with various Extents Type options). |
Extracts the coordinate values that describe an individual feature’s bounding box (or cube) and stores them as attributes. |
Creates a series of regularly-spaced rectangles that span the extent of all features received (when Type of Grid to Create is Polygons). |
Creates a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons). |
Tiler and RasterTiler |
Do not create actual rectangles, but chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator. |
Features with geometry.
Features with geometry replaced with bounding boxes as specified in parameters.
Replace With |
Select the type of bounding box to create:
Long Side Length |
Name the attribute to contain the length of the longest side of the bounding box or cube, in ground units. |
Short Side Length |
Name the attribute to contain the length of the shortest side of the bounding box or cube, in ground units. |
Long Side Angle |
When Replace With is 2D Oriented Bounding Box, name the attribute to contain the angle of the longest side of the bounding box. The angle is measured counter-clockwise from the positive x axis with values between 0 and 180 degrees. |
Search for all results about the BoundingBoxReplacer on the FME Community.
