FME Transformers: 2024.1
MinimumSpanningCircleReplacer
Calculates a circle containing all vertices of the input feature, output as either attribute values or geometry.
Calculating circular boundaries around features
The transformer has two modes:
Replace Geometry - replace the input feature geometry with the circle
Set Attributes - add the center coordinates and radius as attribute values, keeping the input geometry intact.
One circle is generated for each feature or aggregate.
Features with 3D geometry such as 3D objects and point clouds will have a circle generated that encloses their footprint in 2D.
Point features are passed through unchanged (unless they are aggregated or multi-point).
In this example, we have a set of transit lines containing three individual routes.
The features are routed into a MinimumSpanningCircleReplacer.
In the parameters dialog, Mode is set to Replace Geometry.
A circle is generated for each feature, as shown here layered over the original line geometry.
To generate a circle around multiple features, use an Aggregator before the MinimumSpanningCircleReplacer.
This transformer accepts any feature type.
Features with minimum spanning circles as either geometry or attribute values, as specified in parameters.
Mode |
Select a method for handling the calculated circles:
Center X |
When Mode is Set Attributes, name the attribute to contain the center x coordinate. |
Center Y |
When Mode is Set Attributes, name the attribute to contain the center y coordinate. |
Radius |
When Mode is Set Attributes, name the attribute to contain the radius of the circle. |
Search for all results about the MinimumSpanningCircleReplacer on the FME Community.
