You are here: Licensing > Floating Licenses > Installing a Three-Server Redundant Floating License Server On Linux > Download and Run the Installer
Install the floating license server on three different computers using the instructions in sections Before You Begin through Installing a New Floating License.
Send an e-mail to codes@safe.com and include the FlexNet Host ID, the hostname assigned to each of the computers, and serial number. To get your serial number, see the confirmation e-mail you received after purchasing FME Desktop.
We will e-mail you a file called safe.lic that contains the key code file for the license code servers. Copy the safe.lic file into each of the FlexServer directories on your license server nodes.
What's Next?
