You are here: Working with FME Desktop > About List Attributes > How List Attributes Are Created
Attribute lists can be created directly by an FME reader, or they can be added to a feature by a transformer.
Locate the igds_linkage attributes and enable the checkboxes:
  • When the Joiner is used to fetch records related to a feature from a database, and the relation is 1 to many, each of the rows fetched are added toa structured list on the feature. For a detailed example, see Understanding List Attributes.
  • Overlay transformations can optionally create lists of the attributes of the original features that were involved in creating each resultant feature. For an example, see Creating Lists Using Transformers in the FME Knowledge Center.
  • When the Intersector notices overlapping line segments, it makes a list of all the attributes of the overlapping lines and adds this to the output segment.
  • Both the Aggregator and ListBuilder may make lists of the attributes of features that they combine. The lists that are created by transformers such as these can contain very important information to be used in later processing.
