You are here: Administrator's Guide > Installation Options > Distributed Installation > Installing for N-Tier Architecture (3-Tier) > Before Installation
Before Installation
Before you install the FME Server components for a 3-tier architecture, ensure the following non-FME Server components are in place on your network:
- Database server on a separate machine.
- Web application server on a separate machine; or, if using the Web Application Server provided with FME Server, a machine on which to install it.
- File system on a separate machine.
- (Recommended) One or more Windows service accounts with read and write permissions on the network shares of the FME Server Core/Engines and the Web Application Server. In most distributed installations, this account is necessary for these components to communicate with each other across a network. For more information, see Running the System Services Under Different Accounts.
Next Steps
Proceed to Installing for N-Tier Architecture (3-Tier).
