You are here: Administrator's Guide > Installation Options > Distributed Installation > Installing for N-Tier Architecture (3-Tier)
Before installing a 3-tier FME Server architecture, make sure you have:
- Read and understood FME Server and N-Tier Architecture.
- Reviewed Install FME Server: Before You Begin.
- Provided the prerequisites in Before Installation.
To perform a 3-tier installation of FME Server:
- Install the FME Server Core and FME Engines.
- Install the FME Server Services.
- Configure the FME Server Database on your database server.
- Request and Install a License.
- (Upgrade Only) Restore your FME Server Configuration from a Previous Installation.
- (Recommended) Update the Windows service accounts that run the FME System Services.
What's Next?
- Optimize: You can scale-up your FMEServer by:
- Adding FME Engines on separate machines that are closer to your data.
- Increasing the number of FME Engines that run when you start FME Server.
For more information, see Planning for Scalability and Performance.
