| Home | Trees | Indices | Help |
object --+
FMEGeometry --+
FMEArea --+
FMESimpleArea --+
FMEEllipse
init(MultipleInvocations)
FME Ellipse class.
Create an instance of an Ellipse geometry object.
init(boundary)
This routine creates a new Ellipse geometry object from the passed in arc boundry. If this arc is not closed, the closure will be assumed as a complete continuation of the arc where the end point is 360 degrees from the the start point.
boundary (FMEArc) - The boundary as an arc.
Returns: FMEEllipse
init(centerPoint, primaryRadius, secondaryRadius, rotation, orientation)
This routine creates a new Ellipse geometry object using the passed in values.
centerPoint (FMEPoint) - The center point.
primaryRadius(float) - The primary radius.
secondaryRadius(float) - The secondary radius.
rotation(float) - The rotation.
orientation(int) - The orientation rule.
Must be either FME_RIGHT_HAND_RULE or FME_LEFT_HAND_RULE.
Returns: FMEEllipse
init(ellipse)
Create a copy of the passed in Ellipse geometry object.
ellipse FMEEllipse - The Ellipse geometry object to
create a copy of.
Returns: FMEEllipse
FMELine or
None
FMEArc or
None
double
double
double
None
None
None
None
Inherited from Inherited from Inherited from Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This gets the ellipse as a line.
This gets the arc that defines the boundary of the ellipse.
This gets the primary radius of the ellipse. All angles are CCW up from the horizontal and are measured in degrees.
This gets the rotation of the ellipse. All angles are CCW up from the horizontal and are measured in degrees.
This gets the secondary radius of the ellipse. All angles are CCW up from the horizontal and are measured in degrees.
This sets the curve that defines the boundary of the ellipse. If this arc is not closed, the closure will be assumed as a complete continuation of the arc where the end point is 360 degrees from the the start point. If an error occurs, an exception is thrown.
This sets the primary radius of the ellipse to primRadius. All angles are CCW up from the horizontal and are measured in degrees.
This sets the rotation of the ellipse to rotation. All angles are CCW up from the horizontal and are measured in degrees.
This sets the secondary radius of the ellipse to secRadius. All angles are CCW up from the horizontal and are measured in degrees.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
