Class FMEArc
object --+
FMEGeometry --+
FMECurve --+
FMESegment --+
FMEArc
init(MultipleInvocations)
Create an instance of an Arc geometry object.
init(threePoints)
Creates an arc using the 3 points contained in the tuple. If
startPoint and endPoint (threePoints[0] and threePoints[2]) and are
equal, then the arc will be coincident with the circle whose center point
is midway between startPoint and midpoint (threePoints[0] and
threePoints[1]).
threePoints (tuple of FMEPoint) - The tuple containing 3 points to
create the arc.
Returns: FMEArc
An instance of an Arc Geometry object.
init(twoPoints, bulge)
Creates an arc using the 2 points contained in the tuple, and the
supplied 'bulge' value. All angles are CCW up from the horizontal, and
are measured in degrees.
twoPoints (tuple of FMEPoint) - The tuple containing 2 points to
create the arc.
bulge (float) - The bulge value for the arc to be
created.
Returns: FMEArc
init(centerPoint, rotation, primaryRadius, secondaryRadius,
startAngle, sweepAngle)
Creates an arc using the center point supplied, along with the
supplied radii and angles. Measures on the center point will be ignored.
All angles are CCW up from the horizontal, and are measured in
degrees.
centerPoint (FMEPoint) - The centerPoint of the arc.
rotation (float) - The rotation of the arc.
primaryRadius (float) - The primary radius of the arc.
secondaryRadius (float) - The secondary radius of the
arc.
startAngle (float) - The start angle of the arc.
sweepAngle (float) - The sweep angle of the arc.
Returns: FMEArc
startAngle, sweepAngle, startPoint, endPoint)
supplied radii, angles, and points. All angles are CCW up from the
horizontal, and are measured in degrees.
arc.
startPoint (FMEPoint) - (Optional) The start point of the
arc.
endPoint (FMEPoint) - (Optional) The end point of the
arc.
Returns: FMEArc
init(twoPoints, radius, counterClockwise)
supplied 'radius' and points. startPoint and endPoint (twoPoints[0] and
twoPoints[1]) must not be None.
create the arc.
radius (float) - The radius value for the arc to be
created.
counterClockwise (bool) - Whether to create a
counter-clockwise arc.
Returns: FMEArc
init(arc)
Create a copy of the passed in Arc geometry object.
arc FMEArc - The Arc geometry object to create a
copy of.
Returns: FMEArc
__init__(MultipleInvocations)
x.__init__(...) initializes x; see help(type(x)) for signature |
FMEPath
bisectArc()
Returns an equivalent path consisting of two smaller arcs. |
None
None
None
float
FMEPoint
tuple of floats
getMeasureValues(as3Points,
measureName)
Return the values of the measure named by 'measureName', otherwise
returns the values of the defaut measure. |
FMEPoint
getMidPoint()
Returns mid point, which will be interpolated halfway along the arc
if the underlying storage is not by 3 points. |
float
tuple of FMEPoints
tuple of FMEPoints and floats
float
float
float
float
bool
hasExplicitEndpoints()
This returns True if the arc's end points have been
explicitly set, and False otherwise. |
bool
isCW()
This returns True if the arc is clockwise, or
False otherwise. |
bool
isCircular()
This returns True if the arc's primary and secondary
radii are the same length, and False otherwise. |
int
optimalArcTypeRetrieval()
Returns the arc type whose parameters that define the arc can be
retrieved most efficiently and accurately. |
None
None
setMeasureValues(as3Points,
measureTuple,
measureName)
This assigns the values given in the tuple 'measureTuple' to the
default measure, or the measure named by 'measureName' if given. |
None
None
None
None
None
setStartAngle(startAngle)
Sets the start angle of the arc, measured counter-clockwise up from
the horizontal. |
None
setSweepAngle(sweepAngle)
Sets the sweep angle of the arc, measured counter-clockwise up from
the horizontal. |
Inherited from FMECurve:
getAsLine,
getAsLineFixedArcSamples,
getEndPoint,
getLength,
getStartPoint,
isClosed,
isLinear,
offset,
removeDuplicates,
removeMeasure,
reverse,
rotate2D,
scale,
setEndPoint,
setStartPoint,
snip,
snipByPoints
Inherited from FMEGeometry:
__getObject__,
__new__,
boundingBox,
boundingCube,
bounds,
clearMeasures,
copyAttributesFromFeature,
copyNameFromGeometry,
copyTraitsFromGeometry,
copyTraitsToFeature,
deleteName,
force2D,
force3D,
getArea,
getMeasureNames,
getName,
getTrait,
getTraitNames,
getTraitNullMissingAndType,
getTraitType,
hasMeasures,
hasName,
is3D,
isCollection,
measureExists,
removeTraits,
renameMeasure,
setName,
setTrait,
setTraitNullWithType
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
__class__
(Constructor)
- Overrides:
object.__init__
Returns an equivalent path consisting of two smaller arcs. These two
arcs do not necessarily have equal length.
- Returns: FMEPath
- An equivalent path consisting of two smaller arcs.
Converts to an arc by 3 points. If the arc is not circular (isCircular() returns False), then the arc
cannot be converted to arc by 3 points, and an error is returned.
- Returns:
None
- Raises:
Converts to an arc by bulge. If the arc is not circular (isCircular() returns False), then the arc
cannot be converted to arc by bulge, and an error is returned.
- Returns:
None
- Raises:
convertToArcByCenterPoint()
Converts to an arc by center point. If the arc cannot be converted,
then an error is returned.
- Returns:
None
- Raises:
Returns the bulge value. An error is returned if an error occurs.
- Returns:
float
- The bulge value of the arc.
- Raises:
Returns the center point of the arc. An error is returned if an error
occurs.
- Returns: FMEPoint
- The center point of the arc.
- Raises:
measureName)
returns the values of the defaut measure. Returns an error if the measure
does not exist. If 'as3Points' is True, then the values of
the measure are returned as 3 points.
- Parameters:
as3Points (bool) - Whether to return the values as 3 points
measureName (string) - (Optional) The name of the measure whose values to return.
- Returns:
tuple of floats
- The measure values of the arc.
- Raises:
Returns mid point, which will be interpolated halfway along the arc if
the underlying storage is not by 3 points. If an arc is elliptical, an
error is returned.
- Returns: FMEPoint
- The mid point of the arc.
- Raises:
Returns the primary radius of the arc.
- Returns:
float
Returns the arc geometry as a tuple of three points. If the arc is
elliptical, an error is returned.
The structure of the tuple returned is as follows: (startPoint,
midPoint, endPoint).
- Returns:
tuple of FMEPoints
- The arc geometry as three points.
- Raises:
Returns the arc geometry as a tuple of two points and a bulge value.
If the arc is elliptical, an error is returned.
midPoint, bulge).
- Returns:
- The arc geometry as two points and a bulge value.
- Raises:
getPropertiesAsCentered(withEnds)
Returns the arc properties. If 'withEnds' is True, the
end points will be computed and returned. Note that measures are only
stored on the end points. All angles are CCW up from the horizontal, and
rotation is measured in degrees. Also, startAngle and sweepAngle aren't
angles'. Refer to the @Arc (function) in the FME Functions and Factories
manual for a detailed definition of start_angle.
The structure of the tuple returned if withEnds is True
is as follows: (centerPoint, rotation, primaryRadius, secondaryRadius,
The structure of the tuple returned if withEnds is False
- Returns:
Returns the rotation of the arc. All angles are CCW up from the
- Returns:
float
Returns the secondary radius of the arc.
- Returns:
float
- The secondary radius of the arc.
All angles are CCW up from the horizontal. Note: startAngle is a t
angle. Refer to the @Arc (function) in the FME Functions and Factories
manual for a detailed definition of startAngle.
- Returns:
float
All angles are CCW up from the horizontal. Note: sweepAngle is a t
manual for a detailed definition of sweepAngle.
- Returns:
float
explicitly set, and False otherwise. The get() method that
returns end points will calculate the end points if none have been
specified. If this is not desired, this method can be called first to
determine whether the mentioned get() should be called or if the get()
that does not take end points should be called.
- Returns:
bool
True if the arc has explicit end points,
False otherwise.
False otherwise.
- Returns:
bool
True if the arc is clockwise, False
otherwise.
- Returns:
bool
True if the arc is circular, False
otherwise.
- Returns:
int
- The arc type.
setCenterPoint(centerPoint)
Sets the center point of the arc. The arc is converted to an arc by
center point as a result of this method.
- Parameters:
centerPoint (FMEPoint) - The center point to set on the arc.
- Returns:
None
- Raises:
measureTuple,
measureName)
default measure, or the measure named by 'measureName' if given. This
creates the measure if it doesn't already exist.
If 'as3Points' is True, the measure will be set as three
points, hence if measureTuple does not contain three FMEPoint objects,
an error is returned. If the underlying arc is not stored by 3 points,
the "midPoint" value of the tuple (i.e. measureTuple[1]), will
be ignored.
- Parameters:
as3Points (bool) - Whether to set the measure as three points.
measureTuple (tuple of FMEPoints) - The tuple containing the point measures to set on the arc.
measureName (string) - (Optional) The name of the measure whose values to set.
- Returns:
None
Sets the midpoint of the arc. It only sets the midpoint if the arc can
be successfully converted to an arc by mid point.
- Parameters:
midPoint (FMEPoint) - The midpoint to set on the arc.
- Returns:
None
- Raises:
setPrimaryRadius(primaryRadius)
Sets the primary radius of the arc. The arc is converted to an arc by
center point before setting the primary radius.
- Parameters:
primaryRadius (float) - The primary radius to set on the arc.
- Returns:
None
Sets the rotation of the arc. The arc is converted to an arc by center
point before setting the rotation.
- Parameters:
rotation (float) - The rotation to set on the arc.
- Returns:
None
setSecondaryRadius(secondaryRadius)
Sets the secondary radius of the arc. The arc is converted to an arc
by center point before setting the secondary radius.
- Parameters:
secondaryRadius (float) - The primary radius to set on the arc.
- Returns:
None
the horizontal. Note: 'startAngle' is a t angle. Refer to the @Arc
(function) in the FME Functions and Factories manual for a detailed
- Parameters:
startAngle (float) - The start angle to set on the arc.
- Returns:
None
the horizontal. Note: 'sweepAngle' is a t angle. The arc is first
converted to an arc by center point before the 'sweepAngle' is set. Refer
to the @Arc (function) in the FME Functions and Factories manual for a
- Parameters:
sweepAngle (float) - The sweep angle to set on the arc.
- Returns:
None
