FME Donut class.
Create an instance of a Donut geometry object.
Creates a new Donut geometry object. The curve passed in is used to
define the outer boundary of the donut.
Creates a new Donut geometry object. The simple area passed in is used
to define the outer boundary of the donut.
Create a copy of the passed in Donut geometry object.
__init__(MultipleInvocations)
x.__init__(...) initializes x; see help(type(x)) for signature |
None
addInnerBoundaryCurve(innerBoundary)
If the inner boundary being added has a different dimension than the
other boundaries, anything 2D will be forced to 3D. |
None
FMEPath, FMEArc, FMELine or
None
FMEPolygon, FMEEllipse
or None
FMEPath, FMEArc or FMELine
FMEPolygon or FMEEllipse
int
FMEEllipse, or FMEPolygon
None
setOuterBoundaryCurve(outerBoundary)
If the curve is not closed, the closure will be assumed as a straight
line from the start point to the end point. |
None
Inherited from FMEArea:
isBoundaryLinear,
isConvex,
isInPlane,
isOriented,
isPlanar,
offset,
orient,
removeDuplicates,
reverse,
rotate2D,
scale
Inherited from FMEGeometry:
__getObject__,
__new__,
boundingBox,
boundingCube,
bounds,
clearMeasures,
copyAttributesFromFeature,
copyNameFromGeometry,
copyTraitsFromGeometry,
copyTraitsToFeature,
deleteName,
force2D,
force3D,
getArea,
getMeasureNames,
getName,
getTrait,
getTraitNames,
getTraitNullMissingAndType,
getTraitType,
hasMeasures,
hasName,
is3D,
isCollection,
measureExists,
removeMeasure,
removeTraits,
renameMeasure,
setName,
setTrait,
setTraitNullWithType
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
