RasterSubsetter
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
- Clipping a portion of a raster based on number of pixels instead of ground coordinates
- Adding a frame of empty cells around a raster or subset of a raster
The RasterSubsetter accepts raster features, and clips them according to the origin and number of pixels defined.
The subset is defined by a starting column and row, and the number of columns and rows (that is, cells) to be included.
The starting column and row position are offset from the raster origin (0,0), in the upper left corner of the raster. For more information on raster structure, see Rasters (IFMERaster).
The clipped raster (subset) may be padded with empty cells, with settings available for top, bottom, left and right.
In this example, we will extract a portion of a raster image, and add a frame of empty cells around it. Note that the original image is 1600 x 1000 pixels.
The raster is routed into a RasterSubsetter.
The subset will start at Column 300, Row 300, and will be 500 pixels square. We are also adding cell padding - 100 pixels on the left, top, and right, with a wider 300 pixel padding at the bottom.
The output feature is the raster subset, including the padding. Note the new dimensions include both the 500 x 500 cropped image, plus the specified padding.
The output raster, including padding, compared to the extents of the original image:
- To superset a raster, set the Subset to include the entire raster and add Padding.
- To clip a raster by spatial extents, use the Clipper.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
One subsetted raster per input raster feature.
INVALID_RASTER_NO_BANDS
INVALID_RASTER_CANNOT_SUBSET
These parameters specify the position and size of the subset, in cells (pixels), to be taken from the raster. They do not include any padding values.
| Start Column | The position of the starting pixel (x-axis) for the subset. Pixels are counted rightwards from the upper left point of origin. |
| Number of Columns (cells) | The number of cells (pixels) to include to the right of the Start Column. |
| Start Row | The position of the starting pixel (y-axis) for the subset. Pixels are counted downwards from the upper left point of origin. |
| Number of Rows (cells) | The number of cells (pixels) to include below the Start Row. |
These parameters specify how many rows and columns of padding in cells should be placed around the subset portion of the raster.
| Number of Top Padding Rows (cells) | The number of cells (pixels) to add above the subset raster. |
| Number of Left Padding Columns (cells) | The number of cells (pixels) to add to the left of the subset raster. |
| Number of Bottom Padding Rows (cells) | The number of cells (pixels) to add below the subset raster. |
| Number of Right Padding Columns (cells) | The number of cells (pixels) to add to the right of the subset raster. |
Dialog Options - Tables
Search for all results about the RasterSubsetter on the FME Community.
