RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
- Changing raster interpretation type to meet format or processing requirements.
The RasterInterpretationCoercer receives raster features and converts all bands based on a chosen Destination Interpretation Type. Choices include:
- RGB24
- RGBA32
- RGB48
- RGBA64
- Gray8
- Gray16
- Red8
- Red16
- Green8
- Green16
- Blue8
- Blue16
- Alpha8
- Alpha16
- UInt8
- Int8
- UInt16
- Int16
- UInt32
- Int32
- UInt64
- Int64
- Real32
- Real64
Options are available to control the manner in which cell values are converted, handling color to color, numeric to color, color to numeric, numeric to numeric, and floating point to integer conversions.
Band names, if they exist, are retained.
Multi-Band Rasters
When converting to an interpretation with multiple components, such as RGB and RGBA, the input raster will be expected to have exactly 1, 3, or 4 bands. If only one band is supplied, it will be cloned to create the correct number of bands for conversion to the chosen interpretation.
When converting to a single color or numeric interpretation, multiple input bands will be averaged into a single one.
Palettes
If bands selected for conversion contain palettes, the destination interpretation must be an unsigned integer - UInt8, UInt16 or UInt32 to accommodate the palette keys.
In this example, we want to reduce the bit depth and add an alpha band to our original raster, an RGB48 image that has three 16-bit bands - red, green, and blue.
Note the individual cell values for the three bands, which fall in the range of 0 to 65535 (the possible values for a 16-bit band).
The raster is routed into a RasterInterpretationCoercer.
In the parameters dialog, we select a Destination Interpretation of RGBA32.
This choice enables a number of Conversion Options. The transformer is not aware of what type of values it may need to convert, and so provides options for all variations - color, numeric, and float.
For our RGB input raster, the important ones are:
- RGB to RGBA: Create opaque alpha band. This will add an alpha band, and all cells in the band will have the maximum value for the selected bit depth - in this case, 255, as we are converting to 8-bit bands.
The input raster does not have nodata values, and so we cannot create an alpha band from them. - Convert from Color to Color: Scale by data type. Values will be scaled according to the ranges of both the input and output rasters. As we are converting from 16-bit to 8-bit, this means that:
- 0 will become 0
- 65535 (the maximum 16-bit value) becomes 255 (the maximum 8-bit value)
- Values in between are scaled accordingly.
The output raster feature has four bands, including the new alpha band, and all are 8-bit.
The individual cell values have been scaled, and the alpha values are set to 255 (fully opaque).
Note that reducing bit depth may result in a loss of precision. Conversely, increasing bit depth will not increase image quality.
- The RasterBandInterpretationCoercer performs similar conversions on individual bands.
- The RasterPaletteInterpretationCoercer performs similar conversions on palettes.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster features with interpretation type modified and values converted as specified.
INVALID_RASTER_NO_BANDS
| Destination Interpretation Type |
Select the destination interpretation along with the bit depth. Different interpretations allow for different conversion options to be used. If any bands on the raster contain palettes, then the destination interpretation is restricted to UInt8, UInt16 or UInt32. |
| RGBA to RGB |
Select the action to perform when converting four bands representing an RGBA raster to three bands representing an RGB raster.
| RGB to RGBA |
Select the action to perform when converting three bands representing an RGB raster to four bands representing an RGBA raster.
Convert from Color to Color Convert from Numeric to Color Convert from Color to Numeric Convert from Numeric to Numeric |
Select the action to undertake when the given conversion between different types or different bit depths occurs.
* Note: Cast and Bounded Cast use C-style casts. |
| Convert from Float to Integer |
Specifies the action to perform when converting from a floating-point value to an integer.
Dialog Options - Tables
| History | This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers. |
Search for all results about the RasterInterpretationCoercer on the FME Community.
