RasterCellOriginSetter
Sets the cell origin point within cells in a raster.
- Adjusting cell origins to align data from varying formats or sources.
- Adjusting the position, relative to cells, of points produced by vectorizing rasters.
- Adjusting a raster’s cell origin to meet format or processing requirements.
The RasterCellOriginSetter receives raster features and sets the Cell Origin raster property to coordinates between 0,0 and 1,1.
The cell origin differs from the raster origin. The cell origin is a point of reference within every cell, whereas the raster origin refers to point of origin of the entire raster.
0,0 represents the lower left corner of the cell, and 1,1 the upper right.
Lower left (0,0) and center (0.5,0.5) cell origins are common among raster formats, and sometimes need adjustment to align features from different sources.
In this example, we will demonstrate the effect that changing the cell origin has when vectorizing a raster, converting cells to point features.
Note that the source raster has 10 x 10 meter cells (as the ground units of the coordinate system are meters), and the Cell Origin is set to 0.5,0.5 - the center of the cell.
By using RasterCellCoercer transformers to produce both point and polygon geometries of the cells, we can clearly see the center position of the points. We will move them to the corner by altering the Cell Origin.
The raster is routed into a RasterCellOriginSetter, and then on to a RasterCellCoercer transformer to generate points.
In the RasterCellOriginSetter parameters dialog, both the X and Y Cell Origin are set to zero (0).
In the RasterCellCoercer parameters dialog, Output Cell Geometry is set to Points.
The output points, shown here in red against the output raster with its modified cell origin of 0,0, are positioned at the bottom left corner of the cell.
Note that given a cell size of 10 meters by 10 meters, the newly created point's position is approximately 7 meters away from the original cell origin.
- To set origin coordinates for an entire raster, consider using the RasterGeoreferencer.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster features with the cell origin modified according to parameter selections.
INVALID_RASTER_NO_BANDS
| X Cell Origin Y Cell Origin |
Specify the cell origin’s x and y coordinates, where 0,0 is the bottom left and 1,1 is the upper right. 0.5,0.5 represents the center of the cell. Values must be between 0 and 1, inclusive. |
Dialog Options - Tables
Search for all results about the RasterCellOriginSetter on the FME Community.
