RasterCheckpointer
Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations.
- Working around memory limitations in raster processing.
- Performance tuning by forcing raster processing at specific points in a workspace.
The RasterCheckpointer receives raster features and forces the processing of any accumulated raster processing operations, then writes a temporary file to disk of the features’ current state, freeing up memory.
FME handles rasters in a “delayed evaluation” model. A raster reader reads essential information about a raster, but does not read the actual cell contents until it is absolutely necessary. Transformer operations are accumulated until the results are needed, often being held until the features enter a writer. At that point, the required data is fully read and processed.
This is intended to optimize performance - for example, if a raster is both clipped and reprojected, FME will optimize processing by not reprojecting data that falls outside of the clip boundary and is ultimately discarded.
The RasterCheckpointer forces the raster to be fully read (if required) and accumulated operations to be processed immediately, saves the state to disk, and releases the resources that were in use.
RasterCheckpointers are generally not necessary in raster processing workspaces, as data is stored in memory. However, when memory limitations are a factor, such as very large datasets, using the RasterCheckpointer to save the state before performing more operations may lead to performance improvements.
In this example, we will look at how a RasterCheckpointer can improve processing time.
Here, we start with a 2 Gb GeoTIFF source raster, which needs to be reprojected, then pyramided, and finally written with a GeoTIFF writer.
The writer is where both the reprojection and pyramiding operations occur, as can be observed in the status bar while the workspace is running.
The workspace takes over four minutes to run.
Improving Performance
The workspace is modified, adding a RasterCheckpointer between the Reprojector and the RasterPyramider.
The RasterCheckpointer has no parameters to configure.
In this scenario, the reprojection operation takes place in the RasterCheckpointer, is written to disk, and then the pyramiding takes place in the GeoTIFF writer.
Upon running the workspace, the processing time is substantially reduced.
Though RasterCheckpointers are not generally necessary, this specific combination of one very large input raster and two computationally-intensive transformers benefits from using one.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster features with any accumulated raster processing operations applied, the current state saved temporarily to disk, and memory caches cleared.
Dialog Options - Tables
Search for all results about the RasterCheckpointer on the FME Community.
