RasterBandCombiner
Merges coincidental raster features into a single output raster feature, preserving and appending all bands.
- Assembling multi-band rasters from individual band data, such as multi-sensor remote sensing sources
- Combining multiple data bands for convenient storage or processing
The RasterBandCombiner receives groups of raster features with one or more bands, and appends all bands to a single output raster feature.
The rasters to be merged must align exactly. They must have the same number of columns and rows, and georeferenced rasters must have the same coordinates. The rasters may have any number and type of bands, and palettes are preserved.
The order of the input features and the order of the bands of the input features both determine the order of the bands in the output feature. The first band of the first input raster feature becomes Band 0, the second band of the first input raster feature becomes Band 1, and so on. Subsequent raster features' bands are appended sequentially, as they are received.
A Sorter transformer may be used to set the order in which the features are processed, and the RasterBandOrderer may be used to change the band order on individual rasters either before or after the RasterBandCombiner.
Input feature attributes may be optionally merged or retained as a list attribute. A count of input features may be added to a Count Attribute.
In this example, we will merge two numeric rasters into one for convenient storage of two related types of data. The source rasters contain elevation data and aspect, both covering the same area, with the same number of columns and rows.
The elevation raster has one band, with the interpretation type INT32 (32-bit integer). The individual cell values in this raster represent elevation in meters.
The associated aspect raster also has one band, with values representing the direction, in degrees, that the land faces.
Both raster features are routed into a RasterBandCombiner.
In the parameters dialog, the default settings will produce the desired results.
One raster feature is output, with two bands containing the original values from both input features. Note that the raster feature (as viewed in the Data Inspector) appears the same as the elevation input raster feature, as it arrived first in the transformer.
Each cell has two values - elevation integers, and floating point aspect.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
One raster feature per group, with bands appended in the order received, and attributes retained as specified.
INVALID_FEATURE_MISMATCHED_PROPERTIES
| Group By |
The rasters may be organized into groups, with each group of rasters having its own output raster. The properties of each raster within a group, such as the number of rows and columns, must match for the processing to proceed successfully. If georeferenced, the geographic extents of each raster in the group must also be identical. |
| Group By Mode |
| Accumulation Mode |
Drop Incoming Attributes: Attributes from all incoming features are removed, including the first feature. Merge Incoming Attributes: Attributes from incoming features are merged onto the output raster feature. Use Attributes from One Feature: Attributes from the first input raster feature are retained. |
| Count Attribute | If a Count Attribute is given, then an attribute with this name will be added to each output feature, containing the number of features that were combined to create the raster feature. |
Generate List
When enabled, adds a list attribute to the output raster feature, retaining attribute values for each input feature.
| List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
| Add To List |
All Attributes: All attributes will be added to the output raster feature. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen to be added. |
| Selected Attributes | Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be added. |
Dialog Options - Tables
Yes |
| Aliases | RasterBandMerger RasterMerger |
Search for all results about the RasterBandCombiner on the FME Community.
