TopologyBuilder
Computes topology on input point, line, and/or area features, and outputs significant nodes, edges, and faces with attributes describing topological relationships.
Jump to Configuration
  • Computing topological relationships on vector features
  • Finding intersections
The TopologyBuilder computes topology on input point, line, and/or area features.
Topologically significant nodes and lines are computed using all input features and output with additional attributes which describe the topological relationships. The TopologyBuilder will intersect the inputs before building topology, provided the Generate From advanced parameter is set to End Nodes and Intersections. It takes any data and constructs the resulting topology after computing any intersections present in the input data.
It outputs the significant Nodes (points) and Edges (lines) with attributes describing their topological relationships. Faces (areas) are output with information about the Edges which form them.
This transformer is typically used to determine topological relationships to aid in decision making in later transformers.
* Red line indicates direction of flow.
  • The TopologyBuilder will not correct data - it will only find relationships and intersections that exist.
  • Though Z values (elevations) will be retained on features, they are not considered when computing intersections.
Each topological primitive is output with attributes describing its topological relationships. Unlike most transformers, you cannot name these attributes.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
FME Licensing Level FME Base Edition and above
Aliases Topologizer
History
Categories
Spatial Analysis
Search for all results about the TopologyBuilder on the FME Community.
