SpatialRelator
Determines what type of spatial (topological) relationships exist between sets of point, line, area, and text features. Tags - but does not alter the geometry of - features when selected relationships exist, and performs a spatial join to optionally copy attributes between features.
Jump to Configuration
  • Identifying what kind of spatial relationship(s) exist between features
  • Performing a spatial join to transfer attributes from one feature to another based on their spatial relationship
The SpatialRelator takes in two streams of features - Requestors and Suppliers. The Requestors are the features you would like to identify information about, determining what spatial relationship(s) they have with the Supplier features. Only the Requestor features are output from the transformer. Suppliers are used to perform the analysis, and then discarded.
The transformer can be configured to look for one or more specific types of spatial relationship, and to add attributes from the Suppliers to the Requestors. These attributes, as well as the details of the spatial relationships, are (by default) added to the Requestor features as list attributes.
Each input Supplier feature is compared against the Requestor features, based on the tests chosen in the Spatial Predicates to Test parameter. When one of the comparisons is true, an entry is added to the Requestor’s list attribute. The list attribute is only created for features that have a match. Each entry contains:
  • The DE9IM string representing the spatial relationship
  • The name of the type of spatial relationship
  • Attributes from the Supplier (all, some, or none, depending on your selection), performing a spatial join
Every Requestor feature, whether they match a supplier or not, receives a new attribute containing a count of the number of features they match.
Output for a feature that matches two Suppliers might look like this, using default attribute names and selecting a single Supplier attribute for inclusion:
The SpatialRelator does not alter geometry.
  • See Spatial Relations Defined for more information on spatial predicates and an illustration of spatial relationships.
  • Spatial relations are based on the OGC specification and are undefined for geometries that are not OGC valid or aggregate geometries.
  • Aggregates are accepted by a subset of predicates, but should be used with care.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
FME Licensing Level FME Professional Edition and above
Aliases
History
Categories
Data Quality
Filters and Joins
Spatial Analysis
Search for all results about the SpatialRelator on the FME Community.
