Bufferer
Creates a buffer zone of specified size around or inside input geometry.
Jump to Configuration
  • Creating fixed size zones around features, such as rights-of-way or setbacks
  • Determining spatial relationships based on proximity
  • Creating variable size zones around features to represent attribute values
The Bufferer accepts 2D point, curve (line), and area geometries when the Buffer Type is Area (2D). All geometry types are accepted when the Buffer Type is Solid.
Point and lines may be expanded, creating surrounding polygons or solids with points offset by the specified Buffer Amount in ground units. Areas may be expanded or shrunk, using positive or negative Buffer Amounts, but solids require positive Buffer Amounts.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
An optional list attribute may be created, holding multiple attributes for grouped or aggregate input.
  • This transformer creates buffers that are of equal width on either side of a linear input feature. To create offsets to either the left or right-hand side of a feature, use the OffsetCurveGenerator.
  • To buffer features in Geographic (lat/long) coordinates, consider the GeographicBufferer.
  • Areas will be buffered on one side only - externally for a positive Buffer Amount, and internally for a negative Buffer Amount.
  • Output area buffers will always have a Right Hand Rule orientation.
Processing Behavior
Dependent on Group By parameter. If:
Feature Holding
  • Group By Unset: No
  • Group By Set: Yes
Dependencies
FME Licensing Level FME Base Edition and above
Aliases
History
Categories
3D
Spatial Analysis
Search for all results about the Bufferer on the FME Community.
