GeographicBufferer
Creates a buffer zone of specified size around or inside input geometry. Works similarly to the Bufferer, but is designed for use with features in Geographic coordinates. Reprojects input features into the Dynamic Equal Distance projection, buffers them, then reprojects back into the original Geographic coordinates.
Jump to Configuration
  • Creating fixed size zones around features, such as rights-of-way or setbacks
  • Determining spatial relationships based on proximity
  • Creating variable size zones around features to represent attribute values
  • Creating a buffer in different units than the input data
The GeographicBufferer accepts 2D point, curve (line), and area geometries. It reprojects the input features, including those with geographic (lat/long) coordinates, to Dynamic Equal Distance projection, and then creates buffers according to the parameter settings for units, size, and style.
The buffers are then reprojected to match the original coordinate system of the input features, and are output.
Point and lines may be expanded, creating surrounding polygons with points offset by the specified Buffer Amount in ground units. Areas may be expanded or shrunk, using positive or negative Buffer Amounts.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
  • This transformer creates buffers that are of equal width on either side of a linear input feature. To create offsets to either the left or right-hand side of a feature, use the OffsetCurveGenerator along with a Reprojector.
  • To buffer features not in Geographic (lat/long) coordinates, consider the Bufferer.
  • Areas will be buffered on one side only - externally for a positive Buffer Amount, and internally for a negative Buffer Amount.
  • Features must have a coordinate system defined, or they will be output via the Rejected port. The CoordinateSystemSetter may be of use to specify coordinate system if it is missing.
  • The GeographicBufferer will buffer features in any valid coordinate system (geographic or other), and so may be used to create flexible workspaces that can buffer regardless of input coordinate systems and units.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
FME Licensing Level FME Base Edition and above
Aliases
History
Categories
Spatial Analysis
Search for all results about the GeographicBufferer on the FME Community.
