Bentley MicroStation Design (IGDS) Geometry Support
See Also
Geometry |
Supported? |
Notes |
| Aggregates (IFMEAggregate) | No | Will be deaggregated. |
| Yes | ||
| Boxes (IFMEBox) | Yes | |
| BRep Solids (IFMEBRepSolid) | No | Will be split into component lines. |
| No | Will be stroked. | |
| Composite Solids (IFMECompositeSolid) | No | Will be split into component lines. |
| Composite Surfaces (IFMECompositeSurface) | No | Will be split into component lines. |
| Coordinate Precision | Full (32-bit) | |
| CSG Solids (IFMECSGSolid) | No | Will be split into component lines. |
| Yes | ||
| Yes | ||
| Extrusions (IFMEExtrusion) | Yes | |
| Faces (IFMEFace) | No | Will be split into component lines. |
| Feature Table (IFMEFeatureTable) | No | |
| Geometry Definitions and Instances | No | Each instance will become a copy. |
| Georeferencing | Native | |
| Hierarchical Geometries | No | Will be deaggregated. |
| Homogeneous Aggregates | No | Will be deaggregated. |
| Yes | ||
| Measures | No | |
| Meshes (IFMEMesh) | No | Will be split into component lines. |
| No | Will be deaggregated. | |
| Multiple Geometries | No | |
| MultiSolid (IFMEMultiSolid) | No | Will be deaggregated, will be split into component lines. |
| MultiSurface (IFMEMultiSurface) | No | Will be deaggregated, will be split into component lines. |
| No | ||
| Yes | ||
| Yes | ||
| Point Clouds (IFMEPointCloud) | No | Will be boundary. |
| Yes | ||
| Yes | ||
| Rasters (IFMERaster) | No | Will be boundary. |
| Rectangle Faces (IFMERectangleFace) | No | Will be split into component lines. |
| Surface Normals | No | |
| Surface Sidedness | Not applicable | |
| Yes | ||
| Textures | No | |
| Traits | No | |
| Triangle Fans (IFMETriangleFan) | No | Will be split into component lines. |
| Triangle Strips (IFMETriangleStrip) | No | Will be split into component lines. |
| Z values | Yes |
