- Bentley MicroStation Design Reader/Writer
- Design File Quick Facts
- Geometry Support
- V7 Reader Parameters
- V8 Reader Parameters
- V7 Writer Parameters
- V8 Writer Parameters
- Writing Levels in V8 (DEF Line Parameters)
- Feature Representation
- Attribute Linkages
- Attribute Lists – all linkages
- Attribute Lists – string linkage
- Attribute Lists – user linkage
- User Linkages – userId of 22234 and 39030 (Extended entity data linkage)
- Attribute Lists – dbase, odbc, oracle, ris, dmrs, informix linkages
- Attribute Lists – framme linkage
- Attribute Lists – incosada linkage
- Custom Line Styles
- XAttribute Attributes
- Attribute Lists – XFM Linkages
- Attribute Lists – XFM XAttributes
- Arcs
- Cells
- Cells (Shared)
- Complex Shapes Strings
- Curves
- BSpline Curves
- External Reference Files
- Multilines
- Dimensions
- Ellipses
- Lines
- Non-Geometric Collections
- Points
- Polygon Collections
- Shapes
- Solids
- 3D Solids
- Tags
- Multi-text Strings
- Text Nodes
- Text Strings
- XFM Feature Stores
You are here: Popular Formats > Bentley MicroStation Design Reader/Writer > Feature Representation > Attribute Linkages > XAttribute Attributes
Each element in a Design file may have one or more Xattribute attributes attached to it.
Because an element may have more than one XAttribute, these attributes are stored in an FME feature attribute list named igds_xattributes{#}. As with other feature attribute lists, # starts at zero and increments for each successive linkage.
