- Bentley MicroStation Design Reader/Writer
- Design File Quick Facts
- Geometry Support
- V7 Reader Parameters
- V8 Reader Parameters
- V7 Writer Parameters
- V8 Writer Parameters
- Writing Levels in V8 (DEF Line Parameters)
- Feature Representation
- Attribute Linkages
- Attribute Lists – all linkages
- Attribute Lists – string linkage
- Attribute Lists – user linkage
- User Linkages – userId of 22234 and 39030 (Extended entity data linkage)
- Attribute Lists – dbase, odbc, oracle, ris, dmrs, informix linkages
- Attribute Lists – framme linkage
- Attribute Lists – incosada linkage
- Custom Line Styles
- XAttribute Attributes
- Attribute Lists – XFM Linkages
- Attribute Lists – XFM XAttributes
- Arcs
- Cells
- Cells (Shared)
- Complex Shapes Strings
- Curves
- BSpline Curves
- External Reference Files
- Multilines
- Dimensions
- Ellipses
- Lines
- Non-Geometric Collections
- Points
- Polygon Collections
- Shapes
- Solids
- 3D Solids
- Tags
- Multi-text Strings
- Text Nodes
- Text Strings
- XFM Feature Stores
You are here: Popular Formats > Bentley MicroStation Design Reader/Writer > Feature Representation > 3D Solids
3D Solids
igds_type: igds_3d_solid
This is supported for v8 only. This element should not be confused with igds_solid as it correspond to IGDS element type 19 (not to unnamed cell).
FME supports both reading and writing; however, support is currently limited to only extrusions. Work to add support for other solid types is currently underway.
