Reader Directives
The suffix shown is prefixed by the current <ReaderKeyword> in a mapping file.
By default, the <ReaderKeyword> for the C++ TFS Fixed Schema reader is TFS_FIXEDSCHEMA and the <ReaderKeyword> for the Java TFS Fixed Schema reader is com.mycompany.myformat.tfs_fixedschema.tfs_fixedschema.
DATASET
The value for this directive is the TFS Fixed Schema file to be read. A typical mapping file fragment specifying an input TFS Fixed Schema dataset looks like:
TFS_FIXEDSCHEMA_DATASET /usr/data/tfs_fixedschema/dataset.tfs
Required/Optional
Required
Workbench Parameter
Source Text Feature Store (TFS) Fixed Schema File(s)
ENCODING (C++ TFS Fixed Schema)
This optional specification controls which character encoding is used to interpret text attributes from the TFS_VARIABLESCHEMA file. If the value is not set, then the text attributes will all be interpreted using the system encoding.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_ENCODING <encoding>
| Parameter | Description |
| <encoding> |
The character encoding to use when interpreting text attributes. Must be set to any of the following values: ANSI - this means use the “current OS language” BIG5 EUC HKBIG5 ISO OEM SJIS UTF-8 CP437 CP708 CP720 CP737 CP775 CP850 CP852 CP855 CP857 CP860 CP861 CP862 CP863 |
CP864 CP865 CP866 CP869 CP874 CP932 CP936 CP950 CP1250 CP1251 CP1252 CP1253 CP1254 CP1255 CP1256 CP1257 CP1258 ISO8859-1 ISO8859-2 ISO8859-3 ISO8859-4 ISO8859-5 ISO8859-6 ISO8859-7 ISO8859-8 ISO8859-9 ISO8859-11 ISO8859-13 ISO8859-15 WINDOWS-874 |
Workbench Parameter
Character Encoding (optional)
SEARCH_ENVELOPE
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that interact with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE <minX> <minY> <maxX> <maxY>
Note: If all four coordinates of the search envelope are specified as zero, the search envelope will be disabled.
Required/Optional
Optional
Workbench Parameter
Minimum X, Minimum Y, Maximum X, Maximum Y
SEARCH_ENVELOPE_COORDINATE_SYSTEM
This directive specifies the coordinate system of the search envelope if it is different than the coordinate system of the data.
The COORDINATE_SYSTEM directive, which specifies the coordinate system associated with the data to be read, must always be set if the SEARCH_ENVELOPE_COORDINATE_SYSTEM directive is set.
If this directive is set, the minimum and maximum points of the search envelope are reprojected from the SEARCH_ENVELOPE_COORDINATE_SYSTEM to the reader COORDINATE_SYSTEM prior to applying the envelope.
Required/Optional
Optional
Mapping File Syntax
<ReaderKeyword>_SEARCH_ENVELOPE_COORDINATE_SYSTEM <coordinate system>
Workbench Parameter
Search Envelope Coordinate System
CLIP_TO_ENVELOPE
This directive specifies whether or not FME should clip features to the envelope specified in the SEARCH_ENVELOPE directive.
Values
YES | NO (default)
Mapping File Syntax
<ReaderKeyword>_CLIP_TO_ENVELOPE [yes | no]
Workbench Parameter
Clip To Envelope
