The directives that are processed by the Teradata Spatial writer are listed below. The suffixes shown are prefixed by the current <WriterKeyword>_ in a mapping file. By default, the <WriterKeyword> for the Teradata Spatial writer is TERADATA_SPATIAL.
DATASET, HOST, USER_NAME, PASSWORD
These directives operate in the same manner as they do for the Teradata Spatial reader.
The remaining writer-specific directives are discussed in the following sections.
DEF
Each Teradata table must be defined before it can be written.
Mapping File Syntax
The general form of a Teradata definition statement is:
TERADATA_SPATIAL_DEF <tableName> \
[teradata_geometry_column <column>] \
[teradata_geometry_type <type>] \
[teradata_drop_table (yes|no)] \
[teradata_truncate_table (yes|no)] \
[<fieldName> <fieldType>][,<indexType>]*
The table definition allows control of the table that will be created. If the table already exists, the majority of the teradata_spatial_ parameters will be ignored and need not be given. If the fields and types are listed, they must match those in the database.
If the table does not exist, then the field names and types are used to first create the table. In any case, if a <fieldType> is given, it may be any field type supported by the target database.
Required/Optional
Optional
Configuration Parameters
The configuration parameters present on the definition line are described in the following table:
| Parameter | Contents |
| tableName | The name of the table to be written. If a table with the specified name exists, it will be overwritten if either the teradata_overwrite_table DEF line parameter set to YES or if the global writer keyword type teradata_out_overwrite is set to YES. Otherwise the table will be appended. Valid values for table names include any character string devoid of SQL-offensive characters and less than 32 characters in length. |
| teradata_geometry_ | This specifies the name of the column to be created that will hold the geometry when creating a new Teradata table. If this value is set to blank no geometry column will be created and an attribute only table will be written. This may invalidate other geometry related parameters. Default: geom |
| teradata_geometry_type | The type of geometric entity stored within the feature. The valid values for the type are listed below: ST_POINT ST_GEOMETRY Default: ST_GEOMETRY |
| teradata_drop_table | This specifies that if the table exists by this name, it should be dropped and recreated before any features are written to it. Default: NO |
| teradata_truncate_table | This specifies that if the table exists by this name, all the rows in the table should be deleted before any features are written to it. Default: NO |
| fieldName | The name of the field to be written. Valid values for field name include any character string devoid of SQL-offensive characters and less than 30 characters in length. |
| fieldType | The type of a column in a table. The valid values for the field type are listed below: byteint smallint int bigint decimal(width, precision) float char(width) varchar(width) byte(width) varbyte(width) date |
| indexType | The type of index to create on the given field. The valid value for the index type is: PRIKEY(primary key) |
DSN
Required/Optional: Required
The ODBC Data Source Name to use for the DDL statements, i.e., create and drop tables. The DSN must exist and contain the appropriate login credentials.
Example:
TERADATA_SPATIAL_DSN teradata-dbc
Workbench Parameter
DSN
START_TRANSACTION
This statement tells the Teradata writer module when to start actually writing features into the database.
The Teradata writer does not write any features until the feature number of features are skipped, and then it begins writing the features following the specified value.
Normally, the value specified is zero – a non-zero value is usually only specified when a data load operation is being resumed after failing partway through.
Required/Optional
Optional
Mapping File Syntax
TERADATA_OUT_START_TRANSACTION 0
Workbench Parameter
Starting Feature
TRANSACTION_INTERVAL
This directive informs the FME about the number of features to be placed in each transaction before a transaction is committed to the database.
Setting the transaction interval to 0 enables auto commit transaction mode. It is recommended that this number is kept high enough that the overhead of using the TPT API does not have a negative effect on performance.
If this directive is not specified, then a value of 100000 is used as the transaction interval.
Required/Optional
Optional
Mapping File Syntax
TERADATA_OUT_TRANSACTION_INTERVAL 20000000
Workbench Parameter
Features Per Transaction
