You are here: New Formats for 2016 > SAP HANA Non-Spatial Reader/Writer > Writer Feature Type Properties: User Attributes
For information on the parameters in this dialog that are specific to all formats, see About Writer Feature Types: User Attributes
User attributes for this format are defined below.
Name The name of the field to be written.
Type
This section describes the attribute types for a table.
Index
This type is used to create bitmap indexes. A bitmap index stores a bitmap for each index key. Each index key stores pointers to multiple rows. They are primarily designed for data warehousing or environments in which queries reference many columns in an ad hoc fashion.
Indexes and constraints are only created if the table is created.
The valid values for the column type are listed below:
PrimaryKey: This type specifies that the column is a primary key for the table. Only one primary key is allowed per table.
Unique: This type specifies that the column has a UNIQUE constraint.
NotNull: A non-nullable constraint.
UniqueNotNull: An index with a non-nullable and unique constraints.
