Microsoft SQL Server and Azure SQL Database Spatial Reader Parameters
Database Connection
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections.
Note that different subsets of the Database Connection parameters below are made available in different contexts.
This parameter specifies a database connection for the reader through a drop-down menu. The Add Database Connection option in the menu allows for a new connection to be created. The new connection can be made visible only to the current user, or can be shared among multiple users.
Connection Parameters
The host name of the Microsoft SQL Server or Azure SQL database. (It is not necessary to specify a port if a default configuration is used.)
If you have configured your Microsoft SQL Server database to use a non-standard port number, you can specify this port here.
The correct syntax is:
<Host Name or IP>,<port>
The name of the database to connect to.
- Windows Authentication: Select this option when connecting through a Windows user account, and the database can validate the account name and password using the Windows principal token in the operating system. Since the user account is retrieved by Windows, the Username and Password parameters are ignored.
- SQL Server Authentication: Select this option to proceed with specifying login credentials through the Username and Password parameters.
Enter the username and password to access the database, user account, or wherever authentication is required.
Note: Note: This parameter is not present in the Azure SQL Database reader and writer. The Azure SQL Database reader and writer will always request Secure Sockets Layer (SSL) encrypted connections.
When selected, this parameter requests Secure Sockets Layer (SSL) encryption for the connection. If the server does not have a certificate trusted by the client machine, the connection will fail. Otherwise, data will be encrypted before traveling over the network. There are multiple ways to trust a server certificate on a client machine.
If this parameter is not selected, encryption behavior will be determined by encryption properties set for SQL Server Native Client, and for SQL Server.
Note: Tip: When Encrypt Connection is selected, please provide a fully qualified Server name. For example, a server named safe-sql-server might have a fully qualified name of safe-sql-server.dev.safe. This fully qualified name should be an exact match for the server name on the trusted certificate.
The time, in seconds, after which to terminate a query to the database if it has not yet returned a result. If set to zero, there is no timeout. The default is 30.
Constraints
Enter (or browse for) the name(s) of specific database table(s) to extract.
This optional specification is used to limit the rows read by the reader from each table. This example selects only the features whose lengths are more than 2000:
LENGTH > 2000
Schema Attributes
- In a non-dynamic scenario where you have multiple feature types, it is convenient to expose additional attributes from one parameter. For example, if you have ten feature types and want to expose the same attribute in each one, it is easier to define it once than it is to set each feature type individually in the workspace.
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Select this parameter to remove any portions of exported features outside the area of interest.
The illustration below shows the results of the Search Envelope when Clip to Search Envelope is set to No on the left side and Yes on the right side.
- No: Any features that cross the search envelope boundary will be read, including the portion that lies outside of the boundary.
- Yes: Any features that cross the search envelope boundary will be clipped at the boundary, and only the portion that lies inside the boundary will be read. The underlying function for the Clip to Search Envelope function is an intersection; however, when Clip to Search Envelope is set to Yes, a clip is also performed in addition to the intersection.
