You are here: Popular Formats > Bentley MicroStation Design Reader/Writer > Mapping File Directives > Reader Directives for FME Objects
SCHEMA_INCLUDE_MSLINKS
Required/Optional: Optional
This directive can be used for FME Objects only. When set to YES, schema for MSLINKS are added to the feature.
Values: YES | NO
Default Value: NO
SCHEMA_INCLUDE_FRAMME
This directive can be used for FME Objects only. When set to YES, schema for FRAMME linkages are added to the feature.
Values: YES | NO
Default Value: NO
