Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Attributes), this format adds the format-specific attributes described in this section.
Each Hyperion (HDF4) image data subdataset corresponds to a single feature in FME..
Attribute Name |
Contents |
hdf4_hyperion_type |
This will always be hdf4_raster. |
hdf4_hyperion_imagestarttime |
The starting date and time of image collection. |
hdf4_hyperion_dark_offset_method_ |
The dark offset method. |
hdf4_hyperion_swir_scaling_factor |
The SWIR scaling factor used. |
hdf4_hyperion_number_of_cross_track_ |
The number of columns in the raster image. Fixed at 256. |
hdf4_hyperion_file_type |
The type of file generated (ie pre-image dark calibration, image, post-image dark calibration, lamp calibration, post-lamp dark calibration). |
hdf4_hyperion_level0_pre-dark_filename |
The filename for the level 0 pre-dark calibration. |
hdf4_hyperion_frame_number_range |
The data file frame number range. |
hdf4_hyperion_number_of_along_track_ |
The number of rows in the raster image. |
hdf4_hyperion_vnir_scaling_factor |
The VNIR scaling factor used. |
hdf4_hyperion_file_byte_order |
The endianness in which the data is stored. |
hdf4_hyperion_calibration_parameter_ |
The name of the calibration parameter file used to generate the L1R data. |
hdf4_hyperion_echoratiofile |
The name of the echoratio file used to generate the L1R data. |
hdf4_hyperion_time_of_l1_file_ |
The time and date of L1 file generation. |
hdf4_hyperion_scene_id |
The scene id. |
hdf4_hyperion_number_of_bands |
The number of bands in the raster image. Fixed at 242. |
hdf4_hyperion_level0_image_filename |
The name of the level 0 image filename. |
hdf4_hyperion_level0_post-dark_filename |
The name of the level 0 post-dark filename. |
hdf4_hyperion_data_units |
The data units. |
hdf4_hyperion_l1_file_generated_by |
The version of the level 1 processing code used to process the data file. |
hdf4_hyperion_subdataset_name |
When this is present on a feature, the feature is a subdataset. This attribute shows the name of the subdataset. |
hdf4_hyperion_subdataset_description |
When this is present on a feature, the feature is a subdataset. This attribute gives a description of the subdataset. |
