Google Spreadsheet Writer Parameters
Service Connection
Enter a Google Docs username that has access to the spreadsheet to be written.
Enter a Google Docs password for the specified username.
Enter a name for the spreadsheet to be written. If the spreadsheet already exists, click the Browse button, and select the spreadsheet to be written.
Worksheet Creation
If you select Yes, the writer deletes the existing spreadsheet and writes out the new one with the same name. If you select No and the spreadsheet already exists, the features will not be written.
If you select Yes, the first line of the spreadsheet will be written with the field names as column titles.
