Google Spreadsheet Reader Parameters
Service Connection
Enter a Google Docs username that has access to the spreadsheet to be read.
Enter a Google Docs password for the specified username.
Click the Browse button, and select the spreadsheet to be read.
Worksheet Defaults
Indicates whether the field names are specified in the spreadsheet file.
Indicates whether header lines appear before the field names in the spreadsheet file.
Enter the number of header rows in the spreadsheet.
Indicates whether the reader should read formulas from the spreadsheet or actual values.
Schema Attributes
- In a non-dynamic scenario where you have multiple feature types, it is convenient to expose additional attributes from one parameter. For example, if you have ten feature types and want to expose the same attribute in each one, it is easier to define it once than it is to set each feature type individually in the workspace.
