DeLorme GPL (GPS Track Logs) Reader Parameters
Schema Attributes
Additional Attributes to Expose
- In a non-dynamic scenario where you have multiple feature types, it is convenient to expose additional attributes from one parameter. For example, if you have ten feature types and want to expose the same attribute in each one, it is easier to define it once than it is to set each feature type individually in the workspace.
