Autodesk AutoCAD Map 3D Object Data Writer Parameters
File Contents
Specify the AutoCAD release that will be compatible with the output file.
A template file is an AutoCAD file that defines layers, line styles, blocks and shape definitions which are referenced during translation. This option allows you to define the template file by entering a template filename or browsing to a file location.
Note: Note: Template files are also known as prototype files.
