You are here: Popular Formats > Google KML Reader/Writer > Writer Overview and Workbench Parameters > Raw Text
Raw Text
The kml_raw_text format attribute provides a mechanism for users to insert XML snippets directly into the KML document. The value of that attribute will be inserted into the contents of the element that corresponds to the feature being written. This allows users to use features of KML that are not otherwise supported by FME.
Note: It is the user's responsibility to ensure that the value of this attribute is valid XML. Failure to do so may lead to unreadable KML data
