FME Flow: 2026.1
Configuring for HTTPS
HTTPS ensures that communication between the client and server is encrypted, so that if it is intercepted, a third party cannot easily view or use the information.
If your Windows installation of FME Flow uses the Apache Tomcat web application server included with the FME Flow installer, you can configure it for HTTPS if not already done so during installation. On Linux, HTTPS is configured on the NGINX reverse proxy rather than the web application server.
- Skill Level: Intermediate to advanced, depending on certificate type and platform.
- Estimated Time Required: 5-10 minutes (automated), 45-60 minutes (manual).
- Prerequisites:
- Test jobs and services to ensure FME Flow is fully functional. For more information, see Verify the Installation
Familiarity with the Certificate Authority (CA) instructions from your certificate provider, particularly for generating the Certificate Signing Request (CSR).
- (Recommended) Familiarity with your Apache Tomcat web application server's SSL configuration and certificates.
- (Recommended) Access to the person who generates your certificates.
On Windows, there are two supported methods for securing FME Flow with HTTPS. For alternative methods, such as using a self-signed certificate, see Configuring FME Flow for HTTPS.
If you are using a PFX or P12 certificate, a script is provided to handle the configuration. If you are using another form of CA-issued certificate, the configuration must be performed manually.
Using a PFX or P12 Certificate (Automated)
To configure the FME Flow web application server for HTTPS with a PFX or P12 certificate, run the configureSSL.ps1 scripting utility, located in <FMEFlowDir>\Utilities. When finished, restart the FME Flow services.
When running configureSSL.ps1, keep in mind the following:
- You are prompted for the path to your certificate file and the certificate password.
- You must have write access to the FME Flow installation directory.
- The script overwrites all FME Flow Configuration Files with the same values provided during installation. You will lose any changes you made manually to any configuration files since FME Flow was installed. To reference those changes so you can re-apply them, if necessary, back up any configuration files to which you made manual changes prior to running configureSSL.ps1.
- If your installation of FME Flow has the web application server on a separate machine from the core, as with a 3-tier distributed architecture, run configureSSL.ps1 on the web application server host machine. Then, you must manually modify the service URLs to Use HTTPS, as follows:
- In the FME Flow Web User Interface, open the Services page.
- Click Change All Hosts and, in the URL Pattern field, change HTTP to HTTPS. If required, modify the port number—typically SSL is configured on either port 8443 or 443. When finished, click Save.
- After running configureSSL.ps1, you must restart the FME Flow services.
- For more information about running configureSSL.ps1, run configureSSL.ps1 -Help.
Using a CA-issued Certificate (Manual)
This method requires you to generate a certificate signing request from FME Flow, which your IT team can use to create a CA certificate with the .cer or .crt extensions. If the certificate uses the .pfx extension, follow Using a PFX or P12 Certificate (Automated) (above) instead.
- Create a Keystore Generation Script
- Run the Keystore Generation Script
- Open a command prompt as administrator and navigate to the FME Flow installation Java bin directory:
- Execute the command created in step 1.
- Generate a Certificate Signing Request (CSR)
- Obtain a Certificate
- Import the Certificate into the Keystore
- Import the root certificate (if you have one):
- Import the intermediate certificate (If you have one):
- Import the certificate:
- Import the Keystore into FME Flow's trusted certificates
- Back up the Tomcat XML Configuration Files
- Configure server.xml
- Run a text editor as an administrator and open server.xml, located in <FMEFlowDir>\Utilities\tomcat\conf.
- Locate the <Connector> element that contains protocol="org.apache.coyote.http11.Http11NioProtocol" and replace the entire element with:
- Replace <FMEFlowDir> with your FME Flow installation directory, and <password> with the keystore password.
- The list of ciphers is not exhaustive. If your certificate was generated with a different algorithm, the applicable cipher must be added. Any algorithms not in use can be safely removed from this list. For a full list of ciphers supported by Tomcat, see the Apache Tomcat 10 Configuration Reference.
- (Optional) To change the port for HTTPS communication, change 443 to the desired port, for both the port and redirectPort directives.
- Save and close the server.xml file.
- Configure web.xml
- Open web.xml, located in <FMEFlowDir>\Utilities\tomcat\conf.
- Add the following code block to the end of the file, just before the closing </web-app> element:
- Save and close the web.xml file.
- Configure context.xml
- Open context.xml, located in <FMEFlowDir>\Utilities\tomcat\conf.
- Add the following to the end of the file, just before the closing </context> element:
- Save and close the context.xml file.
- Update the FME Flow Web URL to Use HTTPS
- Run a text editor as an administrator and open files fmeFlowConfig.txt and fmeFlowWebApplicationConfig.txt.
- In both files, update the FME_SERVER_WEB_URL directive by changing http to https and change the port to the same one specified in step 8.
- Save and close the files.
- Verify the HTTPS Configuration
- Restart FME Flow.
- Open a web browser and navigate to https://localhost/. If you configured Tomcat to use a port other than the standard port 443, also specify the port (https://localhost:<port>).
- You should see the FME Flow login page in a secured format.
- Modify Service URLs to Use HTTPS
- Click Change All Hosts and, in the URL Pattern field, change HTTP to HTTPS. (FME Flow may have already set this change.) If required, modify the port number—typically SSL is configured on either port 8443 or 443. When finished, click Save.
- Run a sample workspace with the data download and job submitter services to confirm your FME Flow is working with HTTPS.
- (Optional) Enable SSL on the WebSocket Server
- Run a text editor as an administrator and open the fmeWebSocketConfig.txt file in your FME Flow installation directory (<FMEFlowDir>\Server).
- Set
WEBSOCKET_ENABLE_SSL=true. - Uncomment the WEBSOCKET_KEYSTORE_FILE_PATH directive and set it to reference the keystore file set in server.xml in step 8. For example:
- Uncomment the WEBSOCKET_KEYSTORE_FILE_PASSWORD directive and set it to reference the keystore file password set in server.xml in step 8. For example:
- Specify the same settings for the WEBSOCKET_ENABLE_SSL, WEBSOCKET_KEYSTORE_FILE_PATH, and WEBSOCKET_KEYSTORE_FILE_PASSWORD directives in the following files:
- <FMEFlowDir>\Server\config\subscribers\websocket.properties
- <FMEFlowDir>\Server\config\publishers\websocket.properties
- In the following files, update the protocol in the
valueproperty of the PROPERTY directive from"ws:"to"wss:" - <FMESharedResourceDir>\localization\publishers\websocket\publisherProperties.xml
- <FMESharedResourceDir>\localization\subscribers\websocket\subscriberProperties.xml
- Run the following .bat files, located in <FMEFlowDir>\Clients\utilities:
- addPublishers.bat
- addSubscribers.bat
- Restart FME Flow.
- To test that the configuration is complete, run jobs and view Topic Monitoring.
- (Optional) Update the SSO Authentication URL to use HTTPS
- Run a text editor as an administrator and open the fmeserver propertiesFile.properties, located in <FMEFlowDir>\Utilities\tomcat\webapps\fmeserver\WEB-INF\conf\.
- Locate the SINGLE_SIGN_ON_AUTH_URL parameter, and update the host name and port portion of the URL to match the host name through which the FME Flow Web User Interface is accessed.
Open a text editor and copy the example script below, replacing the argument values with your own.
keytool -genkey -noprompt -keyalg RSA -keystore tomcat.keystore -alias <alias> -dname "<dname>" -storepass <storepass> -keypass <keypass> -ext san="<san>" -deststoretype pkcs12
Argument |
Description |
| genkey | The keytool program command to generate a new keystore. |
| noprompt |
Using this argument in the command removes any interaction with the user. |
| keyalg | The algorithm to generate a private/public key pair. |
keystore |
The keystore file name. |
| deststoretype | Keystore type, pkcs12 or jks. |
| dname | The CN name, Organization Unit, Organization, Location (city), State, and two-letter country code. The distinguished name is a set of values used to create the certificate and should be entered as you would like them to be presented to FME Flow users and visitors. |
| storepass, keypass | The password of the key and keystore. The value must be a minimum of six characters and must be the same for both arguments. |
| ext san | The subject alternative name is a structured way to indicate all of the domain names and IP addresses that are secured by the certificate. |
| alias | The name of the key inside the keystore being created. |
Example:
keytool -genkey -noprompt -keyalg RSA -keystore tomcat.keystore -alias tomcat -dname "CN=fmeflow.example.org, OU=support, O=SafeSoftware, L=Surrey, S=BC, C=CA" -storepass password1 -keypass password1 -ext san="dns:fmeflow.example.org,dns:fmeflow" -deststoretype pkcs12
cd <FMEFlowDir>\Utilities\jre\bin\
Where <FMEFlowDir> is the location of the FME Flow installation folder.
In the command prompt, remain in <FMEFlowDir>\Utilities\jre\bin\ and run:
keytool -certreq -keyalg RSA -alias <alias> -file <filename> -keystore tomcat.keystore -ext san="<san>"
Specify the certificate signing request path to the <filename>, and update <alias> and <san> to match that set in step 1.
Example:
keytool -certreq -keyalg RSA -alias tomcat -file certreq.csr -keystore tomcat.keystore -ext san="dns:fmeflow.example.org,dns:fmeflow"
Submit the CSR (for example, certreq.csr) generated in step 3 to your CA to obtain a certificate, according to your CA's instructions.
If you have multiple certificates, install them in the following order, and be sure to update the alias and certificate path for each.
keytool -import -alias root -keystore tomcat.keystore -trustcacerts -file <path/certificate_filename>
keytool -import -alias intermediate -keystore tomcat.keystore -trustcacerts -file <path/certificate_filename>
keytool -import -alias <alias> -keystore tomcat.keystore -trustcacerts -file <path/certificate_filename>
In a command prompt, from <FMEFlowDir>\Utilities\jre\bin\, run the following command, specifying the srckeystore argument with your keystore file name, srcstorepass argument with the password from step 1, and <FMEFlowDir> as the location of the FME Flow installation folder..
keytool -importkeystore -noprompt -srckeystore <tomcat.keystore> -destkeystore "<FMEFlowDir>\Utilities\jre\lib\security\cacerts" -deststorepass changeit -srcstorepass <password>
Navigate to <FMEFlowDir>\Utilities\tomcat\conf and make backups of server.xml, web.xml, and context.xml. We recommend this step so that you can easily revert the configuration at any point if necessary.
<Connector port="443"
connectionTimeout="20000"
maxParameterCount="1000"
URIEncoding="UTF-8"
compression="on"
compressionMinSize="600"
useSendfile="false"
proxyPort="443"
scheme="https"
address="0.0.0.0"
SSLEnabled="true"
secure="true">
<SSLHostConfig
protocols="TLSv1.2+TLSv1.3"
certificateVerification="none"
ciphers="TLS_AES_256_GCM_SHA384,TLS_CHACHA20_POLY1305_SHA256,TLS_AES_128_GCM_SHA256,ECDHE-RSA-AES256-GCM-SHA384,ECDHE-RSA-AES128-GCM-SHA256,DHE-RSA-AES256-GCM-SHA384,DHE-RSA-AES128-GCM-SHA256,ECDHE-RSA-AES256-SHA384,ECDHE-RSA-AES128-SHA256,DHE-RSA-AES256-SHA256,DHE-RSA-AES128-SHA256">
<Certificate
certificateKeystoreFile="<FMEFlowDir>\Utilities\jre\bin\tomcat.keystore"
certificateKeystorePassword="<password>"
type="RSA" />
</SSLHostConfig>
</Connector>
<Connector port="80" protocol="HTTP/1.1" redirectPort="443"/>
<security-constraint>
<web-resource-collection>
<web-resource-name>HTTPSOnly</web-resource-name>
<url-pattern>/*</url-pattern>
</web-resource-collection>
<user-data-constraint>
<transport-guarantee>CONFIDENTIAL</transport-guarantee>
</user-data-constraint>
</security-constraint>
<Valve className="org.apache.catalina.authenticator.SSLAuthenticator" disableProxyCaching="false" />
To submit jobs on FME Flow via HTTPS, you must enable SSL for the FME Flow Web Services.
Your FME Flow is now configured to work via HTTPS. However, if you are using the WebSocket Server or Integrated Windows Authentication, some additional steps are required.
The FME Flow WebSocket Server supports insecure (ws://) or secure connections (wss://). This configuration is only required if you want to use the WebSocket Server or Topic Monitoring (legacy).
WEBSOCKET_KEYSTORE_FILE_PATH=<FMEFlowDir>/Utilities/tomcat/tomcat.keystore
WEBSOCKET_KEYSTORE_FILE_PASSWORD=password1
For example:
SINGLE_SIGN_ON_AUTH_URL=https://<MyFMEFlowHost>:443/fmetoken/sso/generate
SSL for FME Flow on Linux is configured on an NGINX reverse proxy rather than the web application server.
To configure for HTTPS, run the configureSSL.sh scripting utility, located in <FMEFlowDir>\Utilities. When finished, restart the FME Flow services.
When running configureSSL.sh, keep in mind the following:
- You are prompted for the paths to your certificate and private key files.
- The script overwrites all FME Flow Configuration Files with the same values provided during installation. You will lose any changes you made manually to any configuration files since FME Flow was installed. To reference those changes so you can re-apply them, if necessary, back up any configuration files to which you made manual changes prior to running configureSSL.sh.
- If your installation of FME Flow has the web application server on a separate machine from the core, as with a 3-tier distributed architecture, run configureSSL.sh on the web application server host machine. Then, you must manually modify the service URLs to Use HTTPS, as follows:
- After running configureSSL.sh, you must restart the FME Flow services.
- For more information about running configureSSL.sh, run configureSSL.sh -Help.
