FME Transformers: 2026.1
Categories
Calculated Values
Related Transformers
TextAdder
TextLocationExtractor
TextPropertySetter
TextPropertyExtractor
Retrieves text property values from text geometry, adding them to the feature as attributes.
Jump to Configuration
  • Preserving label strings, size, and orientation independent of geometry.
  • Making text properties accessible
  • Storing text properties for use elsewhere in a workspace
The TextPropertyExtractor receives features with text geometry and extracts their properties into attributes.
Extracted properties include:
  • Text String
  • Text Size in ground units
  • Text Rotation in degrees
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
Features without valid text geometry are rejected.
  • This transformer may be useful in conjunction with the TextLocationExtractor when converting labels to non-text geometry.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the TextPropertyExtractor on the FME Community.
