FME Transformers: 2026.1
Categories
Point Clouds
Related Transformers
2DGridCreator
Creator
RasterNumericCreator
RasterRGBCreator
PointCloudCreator
Creates a point cloud of specified size and density, with default component values.
Jump to Configuration
  • Testing a workspace
  • Creating point cloud placeholders
The PointCloudCreator creates a single point cloud feature, based on specified size, location, spacing, rotation, and components. Size may be defined either by an origin with X and Y Length (in ground units), or by extents (lower left and upper right coordinates).
Patterns may be created for z values and/or any other component.
Z Values
Z values may be applied in a selection of patterns:
Flat
The Z Minimum value is applied to all points, producing a flat point cloud.
Sloped
Z values are scaled between the Z Minimum and Z Maximum, producing an elevation gradient.
Trigonometric
Z values are assigned in a trigonometric pattern, producing waves that range between the Z Minimum and Z Maximum values.
The Z Component Type must be floating-point - either Real32 or Real64.
Oblique view:
None
The point cloud will not have a z component - only x and y components.
Components
Other components may also be created and patterned. Standard component names may be selected from the drop-down, and user-defined names can be entered directly. The component Data Type, Min Value, and Max Value are specified.
All component values are applied in the same selected Value Pattern, shown here as an intensity component on a sloped point cloud:
Value Pattern
Value Pattern on a Sloped Point Cloud
Single Value
One component value is applied to all points.
Note the color gradient represents the underlying z value of the Sloped point cloud - not the Single Value component value.
Checkered Pattern
A checkerboard pattern is applied, where one set of blocks is set to Component Values > Min Value.
The alternating blocks are filled with a gradient of component values, scaled between Min Value and Max Value.
Checkerboard
A checkerboard pattern is applied, where one set of blocks is set to Component Values > Min Value, and the alternating blocks are set to Max Value.
This transformer has no input ports.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointCloudCreator on the FME Community.
