FME Transformers: 2026.1
Categories
Calculated Values
Point Clouds
Related Transformers
ExpressionEvaluator
PointCloudComponentAdder
PointCloudComponentCopier
PointCloudFilter
PointCloudOnRasterComponentSetter
PointCloudSorter
PointCloudStatisticsCalculator
RasterExpressionEvaluator
PointCloudExpressionEvaluator
Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.
Jump to Configuration
  • Performing calculations on individual point values within a point cloud
  • Updating point cloud component values
  • Adding new point cloud components
The PointCloudExpressionEvaluator receives point cloud features and evaluates defined expressions using the individual points’ component values, then outputs a point cloud feature with the calculated values applied to existing or new components.
Expressions
Expressions are defined in the right-hand column of the Component Expression(s) table. Each line in the table corresponds to one component, which may be new or existing. Component names may be selected from a list of standard components, or user-specified.
The Data Type for each component is also specified here, and may be set to automatically determine the appropriate type, or to preserve the type of an existing component. Strings are not supported.
Expressions may be as simple a constant value or simple arithmetic operation. The Arithmetic Editor is available via the Expression ellipsis (...) button to assist in the construction of expressions. Point cloud components are available in the editor.
Expressions are case-sensitive.
  • This transformer does not support strings. To add string components, use the PointCloudComponentAdder.
  • This transformer can be used to set an existing component to a constant value by setting the expression to the desired constant.
  • The arithmetic editor is available from the ellipsis (...) button to assist in constructing expressions. See Arithmetic Editor for full documentation.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointCloudExpressionEvaluator on the FME Community.
