FME Transformers: 2026.1
Categories
Calculated Values
Point Clouds
Related Transformers
PointCloudExpressionEvaluator
PointCloudPropertyExtractor
PointCloudSorter
RasterBandMinMaxExtractor
RasterStatisticsCalculator
PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
Jump to Configuration
  • Inspecting and analyzing point cloud features
  • Calculating statistics for use in further operations
The PointCloudStatisticsCalculator receives point cloud features and calculates selected statistics on each one individually. The results are output on each point cloud feature.
Available statistics include:
  • Minimum
  • Maximum
  • Mean
  • Sum
  • Range
  • Standard Deviation
  • Median
  • Mode
Statistics may be calculated for any or all point cloud components.
Statistics are stored as attributes, named <component>.<statisticname>, where <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For example, if the median was calculated for component z, then an attribute named z.median would be added to the feature.
  • To calculate point cloud statistics on a group of point clouds as a single entity, merge them prior to this transformer with the PointCloudCombiner transformer.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the PointCloudStatisticsCalculator on the FME Community.
