FME Transformers: 2025.2
Categories
Database
Workflows
Related Transformers
DatabaseDeleter
DatabaseJoiner
DatabaseUpdater
FeatureJoiner
FeatureMerger
InlineQuerier
ListBasedFeatureMerger
Matcher
SchemaScanner
SQLCreator
SQLExecutor
DatabaseQuerier
Executes queries against a database, producing query results and/or schema.
Jump to Configuration
  • Extract database records as FME features according to a SQL or Cypher statement
  • Execute a database join
  • Perform database table operations (create, drop, modify, truncate)
  • Create or drop indexes or constraints before or after data loading
The DatabaseQuerier connects to a database and runs queries against it.
Query statements are constructed within the transformer, using the appropriate syntax for the database in use. Spatial queries are supported if the database supports spatial predicates.
Output results can be data and/or schema (where supported).
Optional Initiator Port
This transformer has two modes, depending on whether a connector is attached to the Initiator input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Initiator port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Initiator input port is in use, the Initiator output port is also enabled.
  • If the database supports spatial predicates, spatial queries may be used.
  • The SchemaScanner may also be useful as an alternative for producing schemas.
  • For simple joins of one database table to features, the DatabaseJoiner may be more efficient (if the key field(s) are indexed). The DatabaseJoiner does not require knowledge of SQL.
  • If all the data to be queried already exists in a SQL-capable or Cypher-capable data source, it is generally most efficient to use the DatabaseQuerier, SQLCreator or SQLExecutor, as the queries and filtering of the data is executed directly by the database before it enters the FME environment.
  • Features that enter this transformer are not output until the query completes. This behavior ensures that additional DatabaseQuerier transformers, if present, do not execute their queries until the previous query completes.
Processing Behavior
Not applicable
Feature Holding
Not applicable
Dependencies Format-dependent - may require third-party drivers for some formats
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the DatabaseQuerier on the FME Community.
