FME Transformers: 2025.1 BETA
Categories
Cartography and Reports
Related Transformers
LabelPointReplacer
TextAdder
Labeller
Jump to Configuration
  • Annotating linear features
The Labeller receives linear features and generates text labels at intervals along them. Labels are rotated to match the orientation of the segment being labeled, with various size and position parameters.
Collision avoidance and minimum feature length for labeling are both available.
Label Orientation
The orientation of the text varies according to the orientation of the line segment it is placed on. Text is placed parallel to the line segment.
If the line angle produces text that is upside-down (that is, between 90 and 270 degrees), the text is rotated 180 degrees.
Both the line and text angles may be added as an output attribute.
Label Placement Interval and Starting Position
Label intervals are determined by the Label Spacing and Labels at End Points parameters.
If Label Spacing is zero (0), only one label is placed.
This input feature will be labeled with a Label Height of 8. It is 100 meters long.
Action
Result
Place one label at the start of the feature.
Label Spacing: 0
Labels at End Points: Yes
Place one label at the midpoint of the feature.
Label Spacing: 0
Labels at End Points: No
Place labels every 40 meters, and at the first and last points of the feature.
Label Spacing: 40
Place labels every 40 meters, but not at the end points.
Label Spacing: 40
Label Positioning
When an offset is applied to labels, the Label Position parameter determines where label insertion points are placed relative to the feature.
Note that left and right are relative to direction of travel along the feature - they are not the left- and right-hand side of the field of view.
This input feature will be labeled. Note its orientation, indicated by the arrow.
The labels are placed with a large Label Offset value to illustrate position.
Label Position
Placement
Result
Above or Left
Label insertion points are placed above the feature.
Where a line segment is vertical, labels are placed to the left, relative to the feature orientation.
Above or Right
Where a line segment is vertical, labels are placed to the right, relative to the feature orientation.
Below or Left
Label insertion points are placed below the feature.
Below or Right
Left
All label insertion points are placed on the left-hand side, relative to the feature orientation.
Right
  • Although area geometry is accepted, the labels are placed along the perimeter of the feature which may be undesirable. Consider using a LabelPointReplacer instead.
  • Point geometry will be rejected. Consider using a LabelPointReplacer or TextAdder.
  • Awkwardly angled labels might be improved by adjusting spacing or using a Generalizer on the input feature before labeling.
Creating and Modifying Point and Text Features
These transformers work with points, text, and labels in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the Labeller on the FME Community.
