FME Transformers: 2025.1
                                                Retrieves the values of all the feature's coordinates into a single string attribute value, separated by delimiters.
                                                        Extracting coordinate values into attributes for manipulation or use elsewhere
The CoordinateConcatenator receives point, line, area, or donut features and extracts their coordinates into one concatenated and delimited string attribute value.
The delimiters between coordinates and between elements of a coordinate (x, y, and z) may be specified, and can be special characters such as tabs or carriage returns.
Coordinates to include (x, y, and/or z) may be specified in any order, which will be reflected in the output string.
If z is requested on features without z coordinates, it will be ignored.
Aggregates are not supported.
 Example: Concatenating coordinates on area geometries
                                                    In this example, we have a shapefile of parks, and want to extract their coordinates into an attribute. Note that they are in a UTM coordinate system, with ground units in meters.
The features are routed into a CoordinateConcatenator.
In the parameters dialog, the default settings are kept. Note the delimiters - pipe (|)and comma (,).
X, Y, and Z coordinates are requested by default. Our data is 2D, so the Z will be ignored and these default settings are fine.
The output features have a new _coordinates attribute.
On closer examination of the attribute value, we see the coordinates of the polygon, separated by pipe delimiters. Note that the first and last coordinate are identical - indicating a closed area.
 Example: Using special characters as delimiters for formatting
                                                    We can use special characters as delimiters to control formatting.
Using the previous example, in the parameters dialog, we access the Text Editor via the dropdown menu on the Coordinate Delimiter parameter.
The default pipe delimiter is replaced with a carriage return character.
The output attribute value now contains coordinates separated by line, which could be written to a text file with an AttributeFileWriter or used elsewhere.
                                                        To extract coordinates into a list attribute, use the CoordinateExtractor.
 Input
Input
                                                    Features with point, line, area, or donut geometry.
 Output
Output
                                                    Features with coordinates added to an attribute as specified in parameters.
 General
General
                                                    | Coordinate Delimiter | Specify a character or string to be inserted between each set of coordinates. |
| Coordinate Element Delimiter | Specify a character or string to be inserted between each component (x, y, z) of a set of coordinates. |
| Coordinate Element(s) to Include | Specify which elements of a coordinate - x, y, and/or z - to include, in the order in which they are to appear in the output string. If z coordinates are requested, but the data is 2D (has x and y only), z will be ignored. |
 Output Attribute Name
                                                    | Concatenated Coordinates | Name the attribute to store the resulting coordinate values string. |
Transformer parameters can be set by directly entering values, using expressions, or referencing other elements in the workspace such as attribute values or user parameters. Various editors and context menus are available to assist. To see what is available, click  beside the applicable parameter.
 How to Set Parameter Values
 Content Types
Content Types
| Special Characters | A set of control characters is available in the Text Editor. |
 Dialog Options - Tables
| Row Reordering
        | Enabled once you have clicked on a row item. Choices include:
| Cut, Copy, and Paste
| Filter
        | Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output. |
| Import
        | Import populates the table with a set of new attributes read from a dataset. Specific application varies between transformers. |
| Reset/Refresh
        | Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers. |
| Processing Behavior | |
| Feature Holding | No |
Search for all results about the CoordinateConcatenator on the FME Community.
