FME Transformers: 2025.1 BETA
Categories
Coordinates
Geometries
Related Transformers
CoordinateExtractor
GeometryRemover
SpikeRemover
VertexCounter
VertexCreator
VertexRemover
Removes specific vertices from a feature’s geometry.
Jump to Configuration
  • Isolating vertices
  • Removing portions of vector geometry
The VertexRemover receives features with vector geometry and removes specific vertices (coordinates) from them.
Specified vertices may be either removed or kept. If they are kept, all other vertices are removed.
Vertices are identified by their Coordinate Index position, starting at zero (0), and a Number to Keep/Remove, which is extended from the given index position. For example -
  • If keeping coordinates, if the Coordinate Index is 0 and the Number to Keep/Remove is 15, the first 15 vertices will remain and the rest will be removed.
  • If removing coordinates, the first 15 vertices would be removed.
Vertices can also be identified by their position relative to the end of the geometry, where -1 is the last vertex, -2 is second-to-last, and so on. The Number to Keep/Remove will still be extended forwards (towards the end of the feature). For example -
  • If keeping coordinates, if the Coordinate Index is -22 and the Number to Keep/Remove is 22, the last 22 vertices will remain and the rest will be removed.
  • If removing coordinates, the last 22 vertices will be removed.
An attribute _num_removed is added to the features, indicating the number of vertices removed.
Multi- or aggregate geometries, 3D geometries, rasters, point clouds, and non-spatial features will be rejected.
Areas with holes (donuts) will not produce useful results.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases CoordinateRemover
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the VertexRemover on the FME Community.
