FME Transformers: 2025.1 BETA
ArcStroker
Replaces arc or ellipse geometry with interpolated straight line segments.
Preparing geometry for transformation, reprojection, or formats where arcs are not supported
The ArcStroker receives features with vector geometry and converts any arcs to a series of interpolated line segments.
Ellipses are converted to polygons. Paths will have any arc segments stroked while passing through line segments unchanged.
The number of interpolated edges may be determined by:
Letting the ArcStroker choose a reasonable number (default)
Specifying an exact number of segments to create per arc (Stroke By > Number of Interpolated Edges)
Specifying the maximum distance the new line segments may be from the original arc position (Stroke By > Maximum Deviation)
This example shows a circular arc stroked with four (4) interpolated edges:
In this example, we have some transit lines which are composed of lines and arcs. We will stroke the arcs using different settings and examine the results.
The features are in a UTM coordinate system with ground units in meters.
The features are routed into an ArcStroker.
Default: ArcStroker chooses a reasonable number of edges
In the parameters dialog, the default settings of zero (0) interpolated edges are kept. The transformer will calculate a reasonable value.
The output feature, shown in blue over the original arc in yellow, is a line with 23 coordinates. Note that it tightly follows the original arc, and coordinate 4 is highlighted.
The line segments to either side of the arc have been passed through unchanged.
Specifying an exact number of edges
In the parameters dialog, the number of interpolated edges is set to 3.
The output feature, shown in blue with the original arc in magenta, is a line with three segments (and so four coordinates).
It visibly deviates from the original arc, but has few points and so will optimize storage and processing.
Specifying Maximum Deviation to tightly follow an arc
In the parameters dialog, Stroke By is set to Maximum Deviation, with a value of 0.1 meters. This will prevent stroked segments from being positioned more than 10 centimeters away from the original arc.
The output feature, shown in blue over the original arc in yellow, is a line with 44 coordinates. Coordinate 3 is highlighted.
This feature follows the original arc even more tightly than the default setting, producing nearly double the number of interpolated points.
Maximum deviation is a measurement in ground units. Features with a geographic (lat/long) coordinate system may need to be reprojected before using this option.
To reverse arc stroking, consider using the Curvefitter or ArcEstimator.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Transformer |
Use this to... |
Geometry Out |
Z Coordinates |
Create one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replace any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replace any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replace an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modify an existing arc or convert a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modify an existing ellipse (closed arc) or convert a point to an ellipse. |
Supported, at center point |
Extract the property values that describe an arc’s geometry and store them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extract the property values that describe an ellipse’s geometry and store them as attributes. |
Supported |
Convert arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replace geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replace lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduce point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replace an existing feature’s geometry with circle that contains all of its vertices or extract the circle property values into attributes. |
Features with arc or ellipse geometry. Other vector features including points, lines, and areas are passed through unchanged.
Features with arcs and ellipses converted to line or area geometry as specified in parameters.
Features with geometry other than line, arc, path, polygon, or ellipse are output here, as are features with invalid geometry.
INVALID_PARAMETER_NUMBER_OF_INTERPOLATED_EDGES
INVALID_PARAMETER_MAXIMUM_DEVIATION
INVALID_GEOMETRY
Stroke By |
Select a stroking method:
Number of Interpolated Edges |
When Stroke By is Number of Interpolated Edges:
Maximum Deviation |
When Stroke By is Maximum Deviation, specify the maximum distance in ground units that new geometry may be from the original arc. If the this value is greater than the primary or secondary axis of the arc or ellipse, the stroked arc will have the minimum number of edges possible. If less than or equal to 0, the value of Workspace Parameters > Translation > Stroking Tolerance is used. If that value is also less than or equal to 0, the transformer will use Number of Interpolated Edges > zero (0) instead. |
Make Polygon Out of 360 Degree Arcs |
If Yes, arcs with a 360-degree sweep angle are converted into polygons. If No, they are converted into lines. |
Dependencies | None |
Aliases | ClothoidStroker |
History |
Search for all results about the ArcStroker on the FME Community.
