FME Transformers: 2025.1 BETA
Categories
Calculated Values
Related Transformers
2DArcReplacer
2DEllipseReplacer
3DArcReplacer
ArcEstimator
ArcPropertySetter
ArcStroker
Creator
Curvefitter
EllipsePropertyExtractor
EllipsePropertySetter
ArcPropertyExtractor
Extracts the properties of arc geometry, storing the resulting values as attributes.
Jump to Configuration
  • Making arc geometry properties accessible
  • Storing arc geometry properties for use elsewhere in a workspace
The ArcPropertyExtractor receives features with arc geometry and extracts their geometry properties into attributes.
Extracted properties include:
  • Primary Radius
  • Secondary Radius
  • Rotation
  • Start and Sweep Angle
  • Start X, Y and Z coordinates
  • End X, Y and Z coordinates
  • Center X, Y and Z coordinates
Values are calculated and extracted for all requested properties, regardless of the input arc geometry type.
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
Features without valid arc geometry are rejected, including ellipses.
For more information on arc geometry and types, see Arc.
  • Paths with arc segments (such as the output of the Curvefitter) must be split into their components before using the ArcPropertyExtractor. See PathSplitter.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the ArcPropertyExtractor on the FME Community.
