FME Transformers: 2025.1 BETA
Categories
Geometries
Related Transformers
2DArcReplacer
2DEllipseReplacer
ArcPropertyExtractor
ArcPropertySetter
BoundingBoxAccumulator
BoundingBoxReplacer
BoundsExtractor
EllipsePropertyExtractor
EllipsePropertySetter
HullAccumulator
HullReplacer
MinimumSpanningCircleReplacer
Calculates a circle containing all vertices of the input feature, output as either attribute values or geometry.
Jump to Configuration
  • Calculating circular boundaries around features
The MinimumSpanningCircleReplacer receives features with any type of geometry and calculates a 2D circular ellipse that encloses all of the feature’s vertices.
The transformer has two modes:
  • Replace Geometry - replace the input feature geometry with the circle
  • Set Attributes - add the center coordinates and radius as attribute values, keeping the input geometry intact.
One circle is generated for each feature or aggregate.
Features with 3D geometry such as 3D objects and point clouds will have a circle generated that encloses their footprint in 2D.
Point features are passed through unchanged (unless they are aggregated or multi-point).
  • To generate a circle around multiple features, use an Aggregator before the MinimumSpanningCircleReplacer.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the MinimumSpanningCircleReplacer on the FME Community.
