FME Transformers: 2025.1 BETA
Categories
Geometries
Related Transformers
2DBoxReplacer
2DGridAccumulator
2DGridCreator
BoundingBoxAccumulator
BoundsExtractor
Creator
HullAccumulator
HullReplacer
MinimumSpanningCircleReplacer
RasterExtentsCoercer
BoundingBoxReplacer
Jump to Configuration
  • Determining the extents of individual features
The BoundingBoxReplacer receives features with any geometry type and individually replaces their geometry with one of:
  • 2D Bounding Box - the minimum enclosing rectangle, with sides parallel to the x and y axes.
  • 2D Oriented Bounding Box - rotated to fit the feature as tightly as possible while remaining a rectangle.
  • 3D Bounding Cube - the minimum enclosing cube for 3D features, including point clouds. The cube is axis-aligned.
Requesting 2D bounding boxes for 3D features produces footprints. Requesting a 3D bounding cube for a 2D feature produces a 2D box.
If an output bounding box or cube has zero area (if the input feature is a single point or vertical line, for example), it will become a point or line as appropriate.
Feature attributes are retained.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the BoundingBoxReplacer on the FME Community.
