FME Transformers: 2025.1 BETA
Categories
Geometries
Related Transformers
2DGridAccumulator
2DGridCreator
BoundingBoxAccumulator
BoundingBoxReplacer
BoundsExtractor
Creator
RasterExtentsCoercer
2DBoxReplacer
Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values.
Jump to Configuration
  • Creating search envelopes
  • Creating clip boundaries
The 2DBoxReplacer receives features of any kind and replaces their geometry with 2D boxes as specified in parameters.
The parameters describe rectangular geometry with minimum and maximum x and y values, representing the box's lower left and upper right corners, in the ground units of the feature’s coordinate system.
Values may be entered directly or provided via attributes, parameters, or expressions.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the 2DBoxReplacer on the FME Community.
