FME Transformers: 2025.0
EllipsePropertyExtractor
Extracts the properties of ellipse geometry, storing the resulting values as attributes.
Making ellipse geometry properties accessible
Storing ellipse geometry properties for use elsewhere in a workspace
The EllipsePropertyExtractor receives features with ellipse geometry and extracts their geometry properties into attributes.
Extracted properties include:
Primary Radius
Secondary Radius
Rotation
Orientation
Center X
Center Y
Center Z
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
Features without valid ellipse geometry are rejected.
For more information on ellipse geometry see Ellipse.
In this example, we have a set of features with various ellipse geometries and want to extract the properties into attributes for use elsewhere.
Note that the input features have no attributes, but do have geometry properties.
The features are routed into an EllipsePropertyExtractor.
In the parameters dialog, we keep the defaults given for all Output Attribute Names.
The output features have new attributes added, containing the geometry properties.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Transformer |
Use this to... |
Geometry Out |
Z Coordinates |
Create one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replace any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replace any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replace an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modify an existing arc or convert a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modify an existing ellipse (closed arc) or convert a point to an ellipse. |
Supported, at center point |
Extract the property values that describe an arc’s geometry and store them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extract the property values that describe an ellipse’s geometry and store them as attributes. |
Supported |
Convert arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replace geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replace lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduce point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replace an existing feature’s geometry with circle that contains all of its vertices or extract the circle property values into attributes. |
Features with ellipse geometry.
Features with attributes containing geometry property values.
Features without valid ellipse geometry are output via this port.
Rejected features will have an fme_rejection_code attribute with the following value:
Primary Radius |
Name the attribute to contain the length of the primary radius in ground units of the feature’s coordinate system. |
Secondary Radius |
Name the attribute to contain the length of the secondary radius in ground units of the feature’s coordinate system. |
Rotation |
Name the attribute to contain the rotation angle. Rotation is measured in degrees from the horizontal axis to the primary axis in a counterclockwise direction. |
Orientation |
Name the attribute to contain the orientation of the ellipse. The orientation of a feature will follow the right-hand rule or the left-hand rule. |
Center X |
Name the attribute to contain the X coordinate of the center of the ellipse. |
Center Y |
Name the attribute to contain the Y coordinate of the center of the ellipse. |
Center Z |
Name the attribute to contain the Z coordinate of the center of the ellipse. |
Search for all results about the EllipsePropertyExtractor on the FME Community.
