FME Transformers: 2025.0
ArcPropertyExtractor
Extracts the properties of arc geometry, storing the resulting values as attributes.
Making arc geometry properties accessible
Storing arc geometry properties for use elsewhere in a workspace
The ArcPropertyExtractor receives features with arc geometry and extracts their geometry properties into attributes.
Extracted properties include:
Primary Radius
Secondary Radius
Rotation
Start and Sweep Angle
Start X, Y and Z coordinates
End X, Y and Z coordinates
Center X, Y and Z coordinates
Values are calculated and extracted for all requested properties, regardless of the input arc geometry type.
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
Features without valid arc geometry are rejected, including ellipses.
For more information on arc geometry and types, see Arc.
In this example, we have a set of features with various arc geometries and want to extract the properties into attributes for use elsewhere.
Note that the input features have no attributes, but do have geometry properties.
The features are routed into an ArcPropertyExtractor.
In the parameters dialog, we keep the defaults given for all Output Attribute Names.
The output features have new attributes added, containing the geometry properties.
Paths with arc segments (such as the output of the Curvefitter) must be split into their components before using the ArcPropertyExtractor. See PathSplitter.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Transformer |
Use this to... |
Geometry Out |
Z Coordinates |
Create one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replace any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replace any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replace an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modify an existing arc or convert a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modify an existing ellipse (closed arc) or convert a point to an ellipse. |
Supported, at center point |
Extract the property values that describe an arc’s geometry and store them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extract the property values that describe an ellipse’s geometry and store them as attributes. |
Supported |
Convert arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replace geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replace lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduce point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replace an existing feature’s geometry with circle that contains all of its vertices or extract the circle property values into attributes. |
Features with arc geometry.
Features with attributes containing geometry property values.
Features without valid arc geometry are output via this port.
Rejected features will have an fme_rejection_code attribute with the following value:
Primary Radius |
Name the attribute to contain the length of the primary radius in ground units of the feature’s coordinate system. |
Secondary Radius |
Name the attribute to contain the length of the secondary radius in ground units of the feature’s coordinate system. |
Rotation |
Name the attribute to contain the rotation angle. Rotation is measured in degrees from the horizontal axis to the primary axis in a counterclockwise direction. |
Start Angle |
Name the attribute to contain the starting angle of the arc, in degrees counterclockwise from the primary axis (horizontal plus or minus rotation). |
Sweep Angle |
Name the attribute to contain the sweep angle in degrees, which controls the duration of the arc. Positive sweep angles run counterclockwise beginning at the start angle and ending at the sum of the start and sweep angles. Negative sweep angles run clockwise. |
Start X |
Name the attribute to contain the x coordinate of the arc’s start point. |
Start Y |
Name the attribute to contain the y coordinate of the arc’s start point. |
Start Z |
Name the attribute to contain the z coordinate of the arc’s start point. |
End X |
Name the attribute to contain the x coordinate of the arc’s end point. |
End Y |
Name the attribute to contain the y coordinate of the arc’s end point. |
End Z |
Name the attribute to contain the z coordinate of the arc’s end point. |
Center X |
Name the attribute to contain the x coordinate of the arc’s center point. |
Center Y |
Name the attribute to contain the y coordinate of the arc’s center point. |
Center Z |
Name the attribute to contain the z coordinate of the arc’s center point. |
Search for all results about the ArcPropertyExtractor on the FME Community.
