FME Transformers: 2025.0
2DArcReplacer
Replaces or creates feature geometry with a 2D arc as defined in parameters for center point, radii, angles, and rotation.
Creating arc geometry from attribute values or user parameters
Replacing point geometry with arcs defined by values
The 2DArcReplacer receives features of any kind and replaces their geometry with arcs as defined in parameters.
The parameters describe Arc By Center Point geometry with the following:
Center X and Y coordinates
Primary and Secondary Radius in ground units
Start Angle and Sweep Angle in degrees
Rotation in degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
If the Center X and Y coordinates are left blank, the first coordinate of the feature’s existing geometry will be used. If the feature has no geometry, the center is set to 0,0.
For more information on arc geometry and types, see Arc.
In this example, we have a set of points and want to replace them with arcs.
The features are routed into a 2DArcReplacer.
In the parameters dialog, values are entered for radii and angles, but the Center X and Y parameters are left blank.
The points have been replaced by arcs as specified.
If the arc values are unknown and need to be calculated from a line feature, consider using the Curvefitter or ArcEstimator.
The Creator can create alternate arc types Arc By Bulge and Arc By 3 Points.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Transformer |
Use this to... |
Geometry Out |
Z Coordinates |
Create one or more new features with arc geometry (when Geometry Object is an arc type). |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge Ellipse (Arc by center point) |
Supported |
Replace any existing feature’s geometry with a 2D arc. |
Arc by center point |
Replace any existing feature’s geometry with a 3D arc. |
Yes, at center point |
Replace an existing feature’s geometry with a 2D ellipse or circle (closed arc). |
Modify an existing arc or convert a point to an arc. |
Arc by center point Arc by center point with ends Arc by 3 points |
Supported, at center and/or ends |
Modify an existing ellipse (closed arc) or convert a point to an ellipse. |
Supported, at center point |
Extract the property values that describe an arc’s geometry and store them as attributes. |
Arc by center point Arc by center point with ends Arc by 3 points Arc by bulge |
Supported |
Extract the property values that describe an ellipse’s geometry and store them as attributes. |
Supported |
Convert arcs and ellipses to lines or polygons by interpolating points along the arc. |
Path Line Area |
Supported |
Replace geometry with an arc described by the first, middle, and last vertices of the input feature. |
Arc by 3 points |
Supported |
Replace lines or polygons with an optimal combination of line and arc segments, creating smooth curving lines. |
Path Area Arc by bulge Line |
Supported |
Reduce point density on lines or polygons, fitting arcs where possible (When using Algorithm > Douglas With Arc Fitting (Generalize) ). |
Path Area Arc by 3 points Line |
Supported |
Either replace an existing feature’s geometry with circle that contains all of its vertices or extract the circle property values into attributes. |
Center X |
Specify the X coordinate of the arc’s origin. If blank, the X coordinate of the first vertex of the input feature’s geometry will be used. If that feature has no geometry, the value will be zero (0). |
Center Y |
Specify the Y coordinate of the arc’s origin. If blank, the Y coordinate of the first vertex of the input feature’s geometry will be used. If that feature has no geometry, the value will be zero (0). |
Primary Radius |
Specify the primary radius of the arc in ground units. Note that the primary radius need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. For a circular arc, set both the primary and secondary radius to the same value. |
Secondary Radius |
Specify the secondary radius of the arc in ground units. |
Start Angle |
Specify the starting angle of the arc, in degrees counterclockwise from the primary axis (horizontal plus or minus rotation). |
Sweep Angle |
Specify the sweep angle in degrees, which controls the duration of the arc. Positive sweep angles, run counterclockwise beginning at the start angle and ending at the sum of the start and sweep angles. Negative sweep angles run clockwise. |
Rotation |
Specify the rotation in degrees of the primary axis from horizontal (if any). |
Search for all results about the 2DArcReplacer on the FME Community.
