ProjectWiseWSGConnector
Accesses the Bentley ProjectWise service to upload, download, or delete files and folders or list the contents of a folder from a ProjectWise account.
- Manage datasets on ProjectWise by uploading, downloading, and deleting documents and projects.
- Transfer a file's contents (such as XML, point cloud, or raster) into or out of an attribute in FME.
- Read downloaded ProjectWise data using the FeatureReader, or upload data written by the FeatureWriter to ProjectWise.
- Retrieve document and project names, paths, IDs and other information from ProjectWise to use elsewhere in a workspace.
The ProjectWiseWSGConnector uses your ProjectWise account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the ProjectWise service.
Depending on your choice of actions, it will upload files, folders, and attributes; download documents and projects; list information of objects; or delete objects from the service.
The transformer accesses ProjectWise through a Bentley Web Services Gateway (WSG). A WSG is a server-side application that opens a communication channel between an app, in this case FME and the ProjectWiseWSGConnector, and Bentley's project information management system, which in this case is ProjectWise.
A WSG is comprised of two main components. The first component is the WSG framework which uses a REST web services API to communicate with apps to authenticate, send data, and receive data. The second component is a set of providers that communicate directly with individual management systems. The provider of interest to the ProjectWiseWSGConnector is the ProjectWise provider, which allows access to ProjectWise data sources.
- This transformer cannot be used to directly move or copy files between different ProjectWise locations. However, multiple ProjectWiseWSGConnectors can be used to accomplish these tasks.
- The FeatureReader can access ProjectWise directly (without using the ProjectWiseWSGConnector), however, a local copy of the dataset will not be created.
- The minimum supported versions for the ProjectWiseWSGConnector are Bentley Web Services Gateway 2.00 with Server Version 2.00.
The output of this transformer will vary depending on the ProjectWise Action performed.
- After an Upload action, the Instance ID and Object ID of the uploaded object will be set to attributes on the output feature.
- A Download action can save to a file, a folder, or an attribute.
- A Delete action will output the input feature unchanged.
- A List action will output a new feature for each document/project found in the object id specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
ProjectWise Action |
The type of operation to perform. Choices include:
ProjectWise Account |
Performing operations on ProjectWise through a Bentley Web Service Gateway requires the use of a basic authentication using a Web Connection. To create a ProjectWise connection, click the 'ProjectWise Account' drop-down box and select 'Add Web Connection...'. The connection parameters are:
The connection can then be managed via Tools -> FME Options... -> Web Connections. |
The remaining parameters available depend on the value of the Request > ProjectWise Action parameter. Parameters for each ProjectWise Action are detailed below.
ProjectWise Path
Object |
The document or project on ProjectWise to delete. If valid credentials have been provided as a web connection, you may browse to a location. Flat set objects are not supported for delete. |
ProjectWise Source
Object |
The document/project to download. If valid credentials have been provided as a web connection, you may browse to a location. Flat set objects will not be downloaded. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder |
Specify the path to the folder that will store the downloaded document. Valid for Download as File or Folder. |
Include Subfolders |
Choose whether to download subprojects of the ProjectWise Source or not. Valid for Download as Folder only. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded document. Valid for Download as Attribute only. Note FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
ProjectWise Path
Project |
The project to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Output Attributes
Attributes to Add |
The selected attributes will be added to the output feature.
Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. ProjectWise will overwrite documents of the same name. For logical set items, the target document will be overwritten and reference document relationships will be retained. Flat set objects cannot be overwritten. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to ProjectWise if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to ProjectWise if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
ProjectWise Destination
Project |
The project to upload the data to. If valid credentials have been provided as a web connection, you may browse to a location. |
Upload with File Name |
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Output Attributes
Attributes to Add |
Dialog Options - Tables
| Dependencies | Bentley ProjectWise CONNECT Edition, Bentley Web Services Gateway, Bentley WSG ProjectWise Plugin |
| Aliases | ProjectWiseConnector |
| History | Released FME 2018.0 |
Search for all results about the ProjectWiseWSGConnector on the FME Community.
